3bar map sensor install pics ?
Anyone have any pictures of there 3bar map sensor installed? I got all the part numbers and everything i need, i just would like to know how to mount it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 »</TD></TR><TR><TD CLASS="quote">mount it however you want. Pressure to the port, wires to the wires. Then put it somewhere.
So do i just pound in a plastic tee into the throttle body then. Or is there a better way?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebp 99 si »</TD></TR><TR><TD CLASS="quote">here's what i found on hondata's website
http://www.hondata.com/3barinstall.html</TD></TR></TABLE>
yeah i've read over that site already. It didn't help with the mounting question.
dude, you just mount it. i dont know how else to say it, some people zip tie it to a line or firewall somehow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pip9 »</TD></TR><TR><TD CLASS="quote">
Landon
Landon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 »</TD></TR><TR><TD CLASS="quote">
Landon</TD></TR></TABLE>
....i am going to mount it to the firewall...why would i be asking about that.....
I just want to see pictures of how to run the vacuum line. How do i run the line? Do i need to block off the vacuum port on the throttle body where the stock map sensor is and then run the 3 bar off a different source or can i use the port where the stock one is mounted (ie pound a plastic tee into the throttle body port and run it from there). There has got to be a simple way.
Look on the firewall. black thing with a white label.
You are making this harder than it is. Leave the stock sensor where it is but unplug it. Splice the wires from the stock sensor and wire the pigtail to it using the link above.
Hook a vacuum line and increase boost. If you were tuned with the stock sensor you will need to retune with the 3 bar because of the different resolution.
Help?
Help?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 »</TD></TR><TR><TD CLASS="quote">i dont know maybee its just me but POUNDING a plastic tee in your throttle body, sounds kinda ghetto.
no ****, that why i was asking a question on what to do
ladysman...thanks for the actually help. I guess i over thought it. boosted hybrid is going to tune it for me in 2 weeks.
ladysman...thanks for the actually help. I guess i over thought it. boosted hybrid is going to tune it for me in 2 weeks.</TD></TR></TABLE>
No problem. Jeff will know what to do.
da9blk1
Jan 16, 2008 05:04 AM
b18cEK
12
Mar 29, 2006 10:18 AM
