im a new kid with a question.... d16y8 swap into 95 dx coupe?
Old May 30, 2004 | 07:55 PM
skaterdx's Avatar
Default im a new kid with a question.... d16y8 swap into 95 dx coupe?
alright.. i have a newly rebuilt d16y8 and i plan to drop it into my 95 dx.. im keeping my obd1 harness and buying a p28 ecu.. i need to know if my 95 d15 flywheel will work on the y8 and also.. what do i do about the intake manifold, theres a lot more sensors that i dont need.. what do i do with them? or should i not use the y8 intake? thanks
Old May 31, 2004 | 05:00 PM
skaterdx's Avatar
come on.. someone has to know something about this.. i need help.. please
Old May 31, 2004 | 06:41 PM
showtymers619's Avatar
* B A N N E D *
Default Re: (skaterdx)
p28? are you going conversion harness? .. well you need the btec wires wired up.. and also you will need...to change the IACV i think....but all of the sensors should all be reused
Old May 31, 2004 | 08:08 PM
skaterdx's Avatar
maybe im wrong about the p28.. i thought it was an ex/si 92-95 ecu.. and also theres some random sensor mounted on the middle of the fuel rail on the y8 and im not sure what to do with that, and another odd sensor near the crank by the harmonic.. not too sure what to do with that either.. so other than those everything but the iacv should work fine with an obd1 harness?
Old May 31, 2004 | 08:13 PM
* B A N N E D *
yup .. the plug near the pulley you dont need nor the...one on the rail
rayvo
14
Nov 16, 2009 10:33 AM
bunnyx
Apr 30, 2008 01:53 AM
91lsteg
Jul 20, 2007 07:21 PM
JDM Vision
Nov 30, 2006 07:50 PM
FAST AS
15
Dec 24, 2003 03:12 PM
