upper ball joints (emergency)
Old May 30, 2004 | 05:11 PM
Civichatch27's Avatar
Default upper ball joints (emergency)
Do camber kits come with the upper ball joints? Or do i have to buy the upper ball joints and camber kit seperately?
i know...dumb question, i just wanna make sure.
Old May 30, 2004 | 05:21 PM
1's Avatar
Default Re: upper ball joints (Civichatch27)
Camber kits do not come with upper ball joints. They attach to the forks on the fender well side.
Old May 30, 2004 | 05:23 PM
Default Re: upper ball joints (1)
how much do upper ball joints go for?
Old May 30, 2004 | 05:26 PM
1's Avatar
http://www.hondaautomotiveparts.com
Old May 30, 2004 | 05:48 PM
thanks alot for your help.....ill check out the link
Old May 30, 2004 | 05:52 PM
4drEF's Avatar
Keyboard Humorist
Depends on the camber kit. If you get the SPC kit it is basically an adjustabel ball joint. You will need to get a set of 90/91 UCA's and press the upper ball joints out. If you have 88/89 UCA's they have the ball joints welded in and they can't be pressed out.
Old May 31, 2004 | 06:59 AM
Die-Laughing's Avatar
Default Re: upper ball joints (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">Depends on the camber kit. If you get the SPC kit it is basically an adjustabel ball joint. You will need to get a set of 90/91 UCA's and press the upper ball joints out. If you have 88/89 UCA's they have the ball joints welded in and they can't be pressed out.</TD></TR></TABLE>
wow...interesting.
i need to replace my uca's soon also. i work at an autoparts store. so i can get them for cheap. i guess i should just get the 90-91's then.
cool beans
Old May 31, 2004 | 09:50 AM
90civichbsi's Avatar
Default Re: upper ball joints (Die-Laughing)
i got the SPC camberkits.. i like it i figured if im gonna do a camber kit and replace all my balljoints... may as well take 2 things out at once
Old May 31, 2004 | 12:43 PM
Default Re: upper ball joints (90civichbsi)
thanks for all your input guys....
88CRXJ
13
Sep 30, 2009 09:35 PM
AdReNaLiN
Oct 17, 2008 12:00 AM
russianswty
Mar 9, 2007 10:26 PM
turbotime
Apr 14, 2005 09:00 AM
vitrox
Jul 13, 2004 04:37 PM
