upper ball joints (emergency)
Do camber kits come with the upper ball joints? Or do i have to buy the upper ball joints and camber kit seperately?
i know...dumb question, i just wanna make sure.
Keyboard Humorist
Re: upper ball joints (Civichatch27)
Depends on the camber kit. If you get the SPC kit it is basically an adjustabel ball joint. You will need to get a set of 90/91 UCA's and press the upper ball joints out. If you have 88/89 UCA's they have the ball joints welded in and they can't be pressed out.
Re: upper ball joints (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF »</TD></TR><TR><TD CLASS="quote">Depends on the camber kit. If you get the SPC kit it is basically an adjustabel ball joint. You will need to get a set of 90/91 UCA's and press the upper ball joints out. If you have 88/89 UCA's they have the ball joints welded in and they can't be pressed out.</TD></TR></TABLE>
wow...interesting.
i need to replace my uca's soon also. i work at an autoparts store. so i can get them for cheap. i guess i should just get the 90-91's then.
cool beans
wow...interesting.
cool beans
russianswty
03-09-2007 10:26 PM
vitrox
07-13-2004 04:37 PM
