What is the sensor in this pic (B16)?
Old May 30, 2004 | 12:16 PM
7rrivera7's Avatar
Default What is the sensor in this pic (B16)?
Directly above and to the left of the oil filter at 10 o'clock behind the wiring loom (not the arrow which is the knock sensor!)
http://b16a.honda-perf.org/Tech/KNOCK.jpg
It has two wires coming out of it (although you can only see one in the pic). One wire is White/Green and the other is Black.
Old May 30, 2004 | 01:47 PM
JUGGIEGAILS28's Avatar
Default Re: What is the sensor in this pic (B16)? (7rrivera7)
looks like oil pressure to me
Old May 30, 2004 | 02:17 PM
turbohondask's Avatar
Default Re: What is the sensor in this pic (JUGGIEGAILS28)
Is it a older b series motor? If it is it is the fan switch.
Old May 30, 2004 | 08:21 PM
Pssst!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUGGIEGAILS28 &raquo;</TD></TR><TR><TD CLASS="quote">looks like oil pressure to me</TD></TR></TABLE>
Me too
Old May 30, 2004 | 10:43 PM
0554's Avatar
yes are you talkin about the one with two wires? if so its the fan switch.
Old Jun 5, 2004 | 05:51 PM
SOHC Gord's Avatar
oil sending unit
Old Jun 5, 2004 | 07:48 PM
hondaguyef's Avatar
Default Re: What is the sensor in this pic (SOHC Gord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC Gord &raquo;</TD></TR><TR><TD CLASS="quote">oil sending unit </TD></TR></TABLE>
yup
Old Jun 6, 2004 | 12:18 AM
APEX CRX's Avatar
the rubber boot makes is hard to tell but my guess would be oil sending too.
Old Jun 6, 2004 | 01:47 AM
b00sted93Hatch's Avatar
Default Re: What is the sensor in this pic (APEX CRX)
That would be the Oil pressure switch. Thats what triggers the light on your cluster when you dont have oil.
Old Jun 6, 2004 | 03:03 AM
Syner-G-Racing LLC's Avatar
Default Re: What is the sensor in this pic (allMotor93Hatch)
oil pressure switch. trust me. dont believe me...unplug it and watch you oil light come on
Old Jun 7, 2004 | 10:23 PM
Default Re: What is the sensor in this pic (Syner-G-Racing)
it is a fan switch because the oil sender has 1 wire
Old Jun 7, 2004 | 10:28 PM
deepgreengsr's Avatar
Default Re: What is the sensor in this pic (turbohondask)
its not the oil sender cus the sender is one wire and its off to the left side in that pic right next to the oil filter. Looks like a nock sensor to me.
Old Jun 7, 2004 | 10:29 PM
easiest way would be to look in the manual and see what the White/GReen and black wires connect to what sensor. That would be the truth also. verry easy to find out.
projsectEF
16
May 22, 2006 04:19 PM
wullie_vtec
22
Feb 8, 2006 01:52 PM
Pioneer162
Jun 3, 2005 01:51 PM
Audi RS4
Sep 7, 2003 01:56 PM
SleeprCivic
Jun 21, 2003 02:07 AM
