My oil pressure is crazy low, little help here
Old May 29, 2004 | 11:03 PM
boosted_zc's Avatar
Default My oil pressure is crazy low, little help here
When i start the car up cold it jumps to about 70ish psi. As the car warms up it slowly goes down. After driving around for a bit to get it at normal operating temperature, then stopping and idling it's at like 10 psi. This can't be normal. Now i'm not leaking oil anywhere, i've checked everywhere. Oil feed, oil return, oil pan, etc are all not leaking. Anyone have any ideas. By the way what is the normal oil pressure at operating temperature?
Old May 30, 2004 | 06:21 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: My oil pressure is crazy low, little help here (boosted_zc)
Mine seems to sit around 17-18psi when hot @ around 900RPM, 750-800RPM drops to 16...
Old May 31, 2004 | 09:38 AM
Dual Cams's Avatar
is this a freshing new built motor?
Old May 31, 2004 | 09:54 AM
RCautoworks's Avatar
Default Re: My oil pressure is crazy low, little help here (Dual Cams)
If its an older motor, the spacing between the bearings can be to big causing low oil pressure.
an2ny888
May 6, 2013 10:31 AM
Takumi Fujiwara
Jul 22, 2006 04:13 PM
Supahr_Ed
May 27, 2006 11:51 AM
boosted_zc
May 30, 2004 01:50 AM
Snafu-Si
Mar 24, 2003 10:47 PM
