I have a few questions about LSD's.
After owning my R for about 6 months, I have been looking into how to take care of the tranny better.
What kind of LSD additive should I use. If any, is this stuff worth the work. Also, how do I add it. I am assuming that I just do it when I change the tranny fluid. What milage is best to do this at?
The tranny is very noisy, especially when I am reversing and turning the wheels all the way left or right. Is this normal?
Thanks alot in advance. I am new to LSD's and all, so any help or suggestions are appreciated.
well a lot of people use adhesive such as synchro mesh, helps i heard.. but i also heard that it helps when you have slight synchro grind, but in the long run it is bad as it will get worst,i use regualr honda mtf you will be good to go with that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamB18C1 »</TD></TR><TR><TD CLASS="quote">The tranny is very noisy, especially when I am reversing and turning the wheels all the way left or right. Is this normal?</TD></TR></TABLE>
Noise in reverse is normal, that is a straight cut gear. The noise you hear when you have the steering wheel cranked is the power steering pump killing itself, not the tranny. Try to avoid fully locking up the steering.
No LSD additive is needed in a stock tranny. Just stick with good old Honda MTF and you'll be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface »</TD></TR><TR><TD CLASS="quote">
No LSD additive is needed in a stock tranny. Just stick with good old Honda MTF and you'll be fine.</TD></TR></TABLE>
Wow, thanks alot for the info, it helped alot. Should I check out the power steering?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Quikgsr »</TD></TR><TR><TD CLASS="quote">well a lot of people use adhesive such as synchro mesh, helps i heard.. </TD></TR></TABLE>
Adhesive?
For the street, stick with Honda MTF.
Adhesive?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm wannabe »</TD></TR><TR><TD CLASS="quote">the stock ITR LSD does not require additives. Just use Honda MTF</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">For the street, stick with Honda MTF.</TD></TR></TABLE>
So, then explain this: https://honda-tech.com/zerothread?id=879607
Just yanking your chain RJ.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed »</TD></TR><TR><TD CLASS="quote">So, then explain this: https://honda-tech.com/zerothread?id=879607</TD></TR></TABLE>
Street != 15+ track weekends a year. My other car gets MTF, and its fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamB18C1 »</TD></TR><TR><TD CLASS="quote">I was thinking motul, not sure where to get it though. Where did you get yours?</TD></TR></TABLE>
http://www.hmsmotorsport.com - ordered from them several times now,
CivicSwapper
10
Nov 8, 2006 08:48 AM
