b20b... VTEC is not kicking
for some reason i just cant feel or hear the VTEC when I drive. my buddy's b16 you can hear it scream. is it just the b20 or is something wrong. just had to check
it has a 99 si head but doesnt seem to be pulling as hard as it should. but from what everyone is telling me is that you need to build the bottom end first to get some results.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c3 »</TD></TR><TR><TD CLASS="quote">sounds to me maybe u forgot to put a vtec head on it
great advice... thanks for nothing...
</TD></TR></TABLE> great advice... thanks for nothing...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onesikviet »</TD></TR><TR><TD CLASS="quote">no. you can build the head first, i suggest a p&p
I will be almost no help but make sure that the engine is running perfect and at it's full power before you do any upgrades.
</TD></TR></TABLE>I will be almost no help but make sure that the engine is running perfect and at it's full power before you do any upgrades.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eRaceParts.com »</TD></TR><TR><TD CLASS="quote">What kind of Vtec head and intake manifold do you have? The GSR, dual runner manifold is definitely more quiet, but if you have an aftermarket intake and/or exhaust on the car, you should be able to hear it.
Do you have any ecu error codes indicated? If so, check them out, and fix them.
If not try hard wiring the vtec solenoid with a switch directly to 12v. Have someone turn nn the switch or connect the wires when you are driving and the engine is at the proper Vtec RPM and see if you can hear it. This is just to verify that Vtec is switching or not.
Problems that can prevent Vtec from engaging are low oil, level,
low oil pressure, or the ecu not seeing a speed sensor signal.
It's really tough to diagnos your problem since you're not sure that you have one.
Good luck!
im running a b16 head off a 99si the intake manifold is from the same vehicle as well. As for CAI i use the stock honda air box, for the exhaust im running a es oval muffler w/ mandrel bend piping (2.5) its pretty quiet. Im not sure how to check the ecu codes and the wiring... this is the part that i get lost...
oh yeah oil pres and oil are fine.
Good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crex »</TD></TR><TR><TD CLASS="quote">do you have the v-tec oil line ran
where would that be or should be?
the reasons i dont know this is because i had it installed for cheap but now im paying for it
</TD></TR></TABLE>where would that be or should be?
full Circling
Aug 22, 2005 09:05 PM
Touge Tuning
Jan 17, 2005 08:32 AM
LSVTECoupe
17
Dec 12, 2003 03:58 PM
