Removing B16A rocker cover
Old May 29, 2004 | 02:23 PM
-anakist-'s Avatar
Default Removing B16A rocker cover
I've been searching all day for an idiots guide to removing a rocker cover... can anyone help me out?
Old May 29, 2004 | 02:29 PM
dfoxengr's Avatar
Default Re: Removing B16A rocker cover (-anakist-)
rocker cover?
do you mean valve cover?
theres like 8 nuts you remove. all 10mm.
Old May 29, 2004 | 02:50 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -anakist- &raquo;</TD></TR><TR><TD CLASS="quote">I've been searching all day for an idiots guide to removing a rocker cover... can anyone help me out?</TD></TR></TABLE>
You want to remove the 10mm bolts that hold the grey spark plug cover on first. Then remove the 10mm nuts underneath it, and the the 10mm nuts at all 4 corners of the valve cover. Also remove the hose that connects the intake to the valve cover.
Once you remove all of the bolts, you may have to wiggle the valve cover a bit, as it might be stuck, but it will eventually come off.
Do the reverse actions + new gaskets or use some RTV/Hondabond if the gasket is decent, to put it back on.
SteezyEG
12
Oct 28, 2012 02:23 PM
Elmo1968
12
Oct 7, 2005 08:31 AM
civicshowracing65
Oct 20, 2004 03:13 PM
kreamy
Oct 2, 2003 06:43 AM
ActiveAero
Jun 7, 2003 02:31 PM
