Broke a valve cover stud! What to do?
Paragraph Alert
Went out to change the plugs today. After taking off the little grey plug cover I noticed the nuts the hold the little grommets on the valve cover had worked themselves back up (happens almost every time I assume from loosening the nuts on the plastic cover). Anyways when I went to snug it back down one broke off and I don't have enough thread left to put the nut back on. Don't tell me I'm going to have to get the stud replaced . Is it possible for me to just be some gasket seal all around the grommet or is it that important.
Nothing is ever easy.
< is frustrated right now.
ok, it's One of the Four studs that hold the spark plug cover on right?
If so, You can just remove the valve cover and then use a 12mm deep well to remove the stud. No need to tap it out or stuff like that.
You might as well replace ALL of them while you are doing it. I had to do this on a friends car and after I replaced one, another broke. So just replace all 4. Common problem. Nothing to worry about tho.
Re: Broke a valve cover stud! What to do? (ActiveAero)
few people on this board have been running without a few of them for a lil while.
ask emerika. i think he's been running w/o like, 3. lol
just get a new stud...they are cheap and relatively easy to replace
i broke one of mine b4 and it took 5 minutes to replace
The studs are only a couple bucks, and screw right in easy. Not a big deal to replace it. Yes I hate those studs as well, I torque mine to perfect 7.2 lbs-ft each time in the right order and sometimes I still get one stripping from time to time. Thankfully though Honda made it very easy and convenient to replace the studs.
Re: Broke a valve cover stud! What to do? (all stock)
haha..yeah, I ran without one of my valve cover stud/nut for about 2 years. Just replaced it recently. It's easy. Just take off the valve cover and replace the stud.
That happened to me about a month ago...
I couldn't get the stud out, so I had to take it to Honda
They charged me $70 for that.
Without the stud and the rubber seal (ring), oil burst everywhere, and on idle, air is coming out of it.
Does this happen to anyone else?
Re: Broke a valve cover stud! What to do? (boszyen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boszyen »</TD></TR><TR><TD CLASS="quote">That happened to me about a month ago...
Ouch.
Ouch.
Re: Broke a valve cover stud! What to do? (SoCal ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal ITR »</TD></TR><TR><TD CLASS="quote">It's happened before, I don't even keep that little grey valve cover on anymore.</TD></TR></TABLE>
Same here.....my dist side valvecover stud spins in place
I keep the wireplug cover off to save the hassle
Re: Broke a valve cover stud! What to do? (SergEK)
Been running minus 2 forever now...at least a year. No problems here...cake replacement as well. Take off valve cover unscrew stud and screw new one in.
Re: Broke a valve cover stud! What to do? (newgsrdriver)
Yeah I did that a couple weeks ago. The studs around the spark plug cover are Honda part # 90014-PR3-000 and the gold nut that holds the grommet/valve cover is 90212-PR3-000
Paragraph Alert
Thank goodness! I thought for sure I was going to have to get it tapped out by a machine shop or something. Looks like I'll cake it with a touch of gasket seal until I replace it and go ahead and do them all while I'm at it. Thanks for the info.
Honda-Tech has relieved stress once again.
Location: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
i think i overtightened ( which i doubt ) the lower right hand nut on the valve cover. Any idea's on how to get that one off? I think the thread might have been crossed. During my car's downtime i wanted to check it out and remove the valve cover but that nut just sits there and turns. it won't come off. Any idea's on that ?
SteezyEG
12
10-28-2012 02:23 PM
standbackimapro
12-16-2005 11:07 AM
wowowee
24
07-19-2005 05:04 PM
