AEM engine Managment
Old Nov 9, 2001 | 10:29 PM
erikgsr's Avatar
New User
Default AEM engine Managment
Hey guys,
Havent seen the topics lately. I dont know if this was posted already, but does anybody know about the new aem engine management? Is it like the Power FC-more user friendly or like haltech and alike, which are all out for hardcore tuners, not that the Power FC is for a begginer.
Any info would be greatly appreciated
Erik
Old Nov 10, 2001 | 06:26 AM
FAST4DR's Avatar
Default Re: AEM engine Managment (erikgsr)
Erik,
We just received some flyer info on that item. From what I can tell, (they aren't descriptive) it is designed and priced like a DFI setup, but is more geared for the average user. More to come as I hear it. FWIW, my AEM guy told me that it kicks *** over the Power FC, but what do you think he would say, "no, this thing really sucks..."
Old Nov 10, 2001 | 09:41 AM
erikgsr's Avatar
New User
Default Re: AEM engine Managment (FAST4DR)
thanks for the info, Dave. I guess the product is too new to make any conclusions or decisions. But we'll see, AEM has a good rep.
Erik
Old Nov 10, 2001 | 09:50 PM
TypeR_126's Avatar
There's some info on it here:
http://ferrari.colowatch.com/php/sho...sb=5&o=0&part=
Looks to be pretty decent.
Mike
Old Nov 10, 2001 | 10:10 PM
erikgsr's Avatar
New User
Default Re: AEM engine Managment (TypeR_126)
Wow, didnt expect it to be that expensive. Up to $3400, that more than the Power FC i beleive, so we should expect it to be much more capable, but its prob not gonna be the unexpensive Motec replacement.
Erik
Old Nov 11, 2001 | 04:54 PM
Mike K's Avatar
Overpriced. Overrated.
Go with Hondata. Best system you can buy for the money.
Just get a bunch of guys together to go in on a stage 4.. then everyone else get a stage 2. That's the cheapest way you can go, and in my opinion.. Hondata pisses on the Power FC. I've messed around with both of 'em. Hondata rocks.
Old Nov 11, 2001 | 05:03 PM
BABY NSX's Avatar
Default Re: AEM engine Managment (Mike K)
Sorry to rag on you but don't you think you should give the AEM a chance?
Personaly I'd like more info on it, but I realize that it is still very new and that good "qualified" info will be hard to get.
Being in the market for one of these "drop-in" ECUs makes this a very interesting topic for me.
Regards,
Old Nov 11, 2001 | 08:01 PM
lotus's Avatar
New User
Default Re: AEM engine Managment (BABY NSX)
Does the Hondadata ecu use all the origional sensors as well... I hear the AEM does...
Old Nov 11, 2001 | 08:16 PM
Mike K's Avatar
Default Re: AEM engine Managment (lotus)
Hondata is a plug and play unit, and utilizes all OE sensors.
Considering the similarities, the AEM unit is $1500.00 I think, and the Hondata is $1195.00 for the full stage 4.
But if you have a friend with a stage 4 all you need is the stage 2, which is $395.00 I think.
Much more cost-effective if you ask me.
Old Nov 11, 2001 | 09:31 PM
TypeR_126's Avatar
Of course, once you add in the price of an OBD1 ECU and a harness adapter, you're pretty much at the same price! It will probably come down to if you want some of the Hondata extras, like launch control and full-throttle shift.
Mike
[Modified by TypeR_126, 10:31 PM 11/11/2001]
Old Nov 12, 2001 | 06:21 AM
Mike K's Avatar
Good point. I overlooked that because I am putting Hondata in my 92 CX which is already OBD1...
umm.. yeah for a ITR I guess there are a few options with equivalent perks..
Old Nov 12, 2001 | 06:37 AM
Crossett's Avatar
You have to burn new chips each time for the Hondata. the Zdyne just lets you reprogram, thats prolly what i'll end up with.
[Modified by Crossett, 9:45 AM 11/12/2001]
Old Nov 12, 2001 | 08:10 AM
Mike M's Avatar
Founding Member
Default Re: AEM engine Managment (Crossett)
Power FC
Old Nov 12, 2001 | 09:27 AM
BABY NSX's Avatar
Default Re: AEM engine Managment (TypeRmsm)
Power FC
The Power FC has definitely been the popular king of the hill lately as far as programmable ECUs go, and at $1300 it is a good buy!
BUT the Power FCs biggest weakness is in the software support for us English-speaking folks. If the AEM is everything it looks like it is then it will give the Power FC a good run for it's money. And with the software there the AEM might just come out on top. Time will tell. Personally I think that Apex has dropped the ball on this side of the market. The power FC is not even on their web site
Oh, and a question for those that might know: Can the AEM (or PowerFC for that matter) use the wide-band Honda O2 sensors to run closed loop?
I know that the AEM pro kit does but they don't mention if their drop in kit does or not. This is a big deal because if this is possible then we can finally hook up a true O2 sensor to the ECU and tune fuel ratios off the dyno.
Regards,
Old Nov 12, 2001 | 10:32 AM
BABY NSX's Avatar
Just spoke with a tech at AEM this is what he said:
The PnP version does support UEGO Honda's wide band O2 sensor. This means that the ECU will not only be able to run closed loop in higher air/fuel ratios (i.e. fewer emissions and better mileage) but also be useful as an accurate air/fuel meter for tuning purposes. Not sure if the PowerFC has this or not.
The units will be available in early 2002
The preliminary pricing is: $1868 for the PnP and $2368 for the full race system.
The systems will also be pre programmed with mappings for specific models (i.e. GSR, TypeR, Si, etc.)
There will also be some sort of dashboard display available.
That's all I looked into.
Regards,
Old Nov 12, 2001 | 10:00 PM
erikgsr's Avatar
New User
PREPROGRAMMED is Good.
Old Nov 30, 2001 | 12:15 PM
Striker's Avatar
New User
What's the difference between the PnP version and the full race version?
Old Nov 30, 2001 | 01:13 PM
BABY NSX's Avatar
Default Re: AEM engine Managment (Striker)
PnP version will plug into the factory wire harness. The full race version uses a universal connector. AEM says that the internals are the same. You may have to do some custom wiring if you want to take advantage of some of the "extra" features in the PnP version because the factory harness doesn't carry all the signals (i.e. Exhaust Gass Temperature, Wide-Band 02 sensor).
There isn't much info on these systems yet because they have not been released. Early December for the Pro kit and early 2002 for the PnP kits.
Regards,
Old Dec 16, 2001 | 08:03 PM
94cxHybrid's Avatar
New User
actually you can get a rebrnable chip for hondata. Just thought i would let you know.
Old Dec 16, 2001 | 09:04 PM
naturalvx's Avatar
Default Re: AEM engine Managment (94cxHybrid)
Yes but AEM is on the fly all the time, not when you have your Stage 4 or you buddies stage4 waiting to burn a new chip.
Old Dec 20, 2001 | 07:42 PM
ekb18c's Avatar
Default Re: AEM engine Managment (naturalvx)
AEM= Good stuff
A True Standalone ecu that has no limits, data logging, Plug and Play(uses factory harness), windows OS, 32 bit system.
$1480 -Doing a groupbuy, Reserves your today.
Haltech = 1,400 with all nessary componets (map sensor, terminal harness etc) And offcourse tuning on dyno .~170/hour
Hondata= 1,100 BUT you will need a 0bd2 to obd1 harness(~$250) from skunk2 or others and then a obd1 ecu(~$300). (For you force induction people it can only support up to 20psi's i think)
Old Dec 20, 2001 | 07:55 PM
Type R's Avatar
Default Re: AEM engine Managment (ekb18c)
aem sounds good so far
ALL IMPORT
Jun 18, 2009 05:54 PM
AssPenny
Jun 21, 2007 12:36 AM
EH-3
Nov 19, 2005 07:22 PM
PrecisionH23a
Aug 8, 2005 09:23 AM
trooper0641
11
Apr 6, 2004 05:27 PM
