California BAR Sticker on a stock motor?
Old May 29, 2004 | 08:33 AM
Hoodwinked's Avatar
Default California BAR Sticker on a stock motor?
Hi, I might be getting a 1998 civic hatch and I have a few quetions about getting BARed. First off, can I take my 100% stock car in there and get a BAR sticker so it says the motor is a "Honda 1.6L"? If so, could I then after I get the bar just swap in my b16b and I wont get bugged because it is still a "Honda 1.6L" so they wont know what motor I actually got barred. Does California let you get the stock motor barred? Thanks
Old May 29, 2004 | 10:27 AM
cpforyou's Avatar
Default Re: California BAR Sticker on a stock motor? (Hoodwinked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoodwinked &raquo;</TD></TR><TR><TD CLASS="quote">Hi, I might be getting a 1998 civic hatch and I have a few quetions about getting BARed. First off, can I take my 100% stock car in there and get a BAR sticker so it says the motor is a "Honda 1.6L"? If so, could I then after I get the bar just swap in my b16b and I wont get bugged because it is still a "Honda 1.6L" so they wont know what motor I actually got barred. Does California let you get the stock motor barred? Thanks</TD></TR></TABLE>
That's a good question. I'd like to know too!
Old May 29, 2004 | 11:23 AM
Hoodwinked's Avatar
bump for an answer
Old May 29, 2004 | 12:16 PM
AMS MIKE's Avatar
Call the State Referee and they will tell you everything you need to know!
(800) 622-7733
http://www.dca.ca.gov/
Old May 29, 2004 | 12:24 PM
Hoodwinked's Avatar
Default Re: California BAR Sticker on a stock motor? (AMS MIKE)
lol ya call and say what? "Can I get the stock engine BAR certified?" and they would reply "Why do you need it BARed?". "Umm...." Or....could I claim I replaced the engine with different one and swapped the VIN tags on the block?
Old May 29, 2004 | 01:20 PM
AMS MIKE's Avatar
As long as you have a motor that is the same year as the car and or newer, and you have all the US smog equipment hooked you, you can put any motor in your hatch. Internals must be stock.
examples:
1998 hatch and you put a 1999 JDM B16B.
YOU MUST:
-have all US smog equipment off a 99-00 civic si
-stock B16B head and block and tranny with id #'s on them. They will run the numbers and they will smog the car and do visual as if its a 99-00 civic si but its a JDM motor.
You may also have bolt ons ONLY if they are CAARB approved.
I have BAR'd a few of my cars and its great! You get pulled over and they see a Type R or GSR or Prelude in a hatch and start writing you up and you just laugh at them, wait until they are done, show them the BAR sticker on the car and the cop just rips up the ticket...priceless!
Its a lot of work to make it pass the BAR/Smog...but it can be done.
just make sure you have ALL USDM parts except for the head, block and tranny. Must have a USDM ecu too.
GOOD LUCK!
Old May 29, 2004 | 04:41 PM
STEV3-O's Avatar
sorry cant smog the b16b never produced in vehicles brought to the states.
Old May 29, 2004 | 06:10 PM
AMS MIKE's Avatar
Default Re: California BAR Sticker on a stock motor? (sleepingeg6)
State Referee told me that they will look at the engine bay and motor as if its a B16 in a 99-00 si. That means you have a B16B head and bloack and all other equipment in the engine bay is routed as if you are looking in a 99-00 civic so engine bay and using a USDM ECU.
just what I was told by the Ref's themselves when I BAR'd my cars
Old May 29, 2004 | 07:56 PM
michael O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMS MIKE &raquo;</TD></TR><TR><TD CLASS="quote">State Referee told me that they will look at the engine bay and motor as if its a B16 in a 99-00 si. That means you have a B16B head and bloack and all other equipment in the engine bay is routed as if you are looking in a 99-00 civic so engine bay and using a USDM ECU.
just what I was told by the Ref's themselves when I BAR'd my cars </TD></TR></TABLE>
I believe that all the refs say different things.
Old May 30, 2004 | 06:20 PM
Lord Helmet's Avatar
that won't work since the BAR sticker will say SOHC 1.6 on it. the majority of BAR approved cars I've seen with a b-series swap will say DOHC 1.6 or 1.8 so basically you won't fool the refs on this one.
Old Mar 5, 2011 | 11:20 AM
danielg4l's Avatar
So I have a 98 integra and am about to get a b20 swap...can I get this Bar'd?
Old Mar 5, 2011 | 11:27 AM
danielg4l's Avatar
So If I get a B20 on my DC I should be fine for a bar..?
Old Mar 5, 2011 | 01:33 PM
JThrasher79's Avatar
short answer is no.
Old Mar 7, 2011 | 09:32 AM
danielg4l's Avatar
why would it be a no?
Old Mar 14, 2011 | 10:32 AM
pillclinton's Avatar
the b16b was not offered in the u.s. so that makes it NOT legit
as for the b20 in an integra you CANT get it barred
since im so nice here you go...
http://www.bar.ca.gov/80_BARResource...uidelines.html
Old Mar 16, 2011 | 01:46 PM
dude_123's Avatar
Talk to your local BAR Referee, if they are up to date with their info the B20 are a direct replacement motor for 94-01 DC(X) chassis, which means no need to be BAR'd; again, if they are up to date with their info which means it varies from person to person.
But, for a fact smog techs are not up to date or informed with any new news from the state, so don't be surprised to be sent to the ref if you have a B20 motor in a DC(X).
Old Mar 17, 2011 | 07:56 PM
93h2beg's Avatar
WRONG
last time i checked (feb 2011) a b20 is still a truck motor and CANNOT swap into a car chassis legally
Old Mar 28, 2011 | 06:44 PM
rhymeshark916's Avatar
This is impossible. Obviously, D series and B series are different families. So to answer your question, no. Case in point, my friend has a Bar'd 96 h/b with a B18b. On his sticker, it says " Acura B18 replacement." So technically, he can put in any B18's in there. I guess he got lucky.
civicSF98
Feb 11, 2010 11:32 AM
EK79
Apr 10, 2006 02:07 PM
I got a honda
Apr 1, 2006 02:16 PM
95civickid
Jul 27, 2005 01:28 PM
B16CivicHB
Jan 20, 2002 12:04 PM
