BAR
Old Mar 29, 2006 | 10:00 AM
I got a honda's Avatar
Default BAR
to BAR my car in cali do i need to have the same year motor as my car or newer or does it matter??.....thanks
Old Mar 29, 2006 | 10:19 AM
RHDintegXsi's Avatar
Default Re: BAR (iluvboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvboost &raquo;</TD></TR><TR><TD CLASS="quote">to BAR my car in cali do i need to have the same year motor as my car or newer or does it matter??.....thanks</TD></TR></TABLE>
yes..they will be checking..state ref's are really good at inspecting hondas and they dont let much pass by them
Old Mar 29, 2006 | 10:20 AM
purplegsr's Avatar
same year or newer only
This is a very helpful post from Spade about BAR rules and getting your car ref'd successfully:
https://honda-tech.com/zerothread?id=385337
Old Mar 29, 2006 | 10:54 AM
DC2 Mang's Avatar
I thought you could only BAR a motor newer than the make of your vehicle
anyways, if it is a hybrid motor like ls/b20vtec dont even bother trying
you have to make sure all vacuum lines are correct, and all wiring is correct and covered as well
Old Mar 29, 2006 | 10:56 AM
purplegsr's Avatar
Default Re: BAR (JDMdc2lsVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdc2lsVtec &raquo;</TD></TR><TR><TD CLASS="quote">I thought you could only BAR a motor newer than the make of your vehicle
Nope, it could be from the same year as well. Just nothing older.
Old Mar 29, 2006 | 11:01 AM
DC2 Mang's Avatar
Default Re: BAR (purplegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr &raquo;</TD></TR><TR><TD CLASS="quote">
Nope, it could be from the same year as well. Just nothing older.</TD></TR></TABLE>
good to know, thanks
Old Mar 29, 2006 | 12:11 PM
hhmm because im gonna try n bar a 94-95 stock ls in my 97 gsr.....guess im screwd.....what if i change the head to a 97+??
Old Mar 29, 2006 | 12:14 PM
Lauj87's Avatar
yeah you would be okay with a 97 up motor..but as far as your LS motor now...your screwed....
Old Mar 29, 2006 | 12:15 PM
purplegsr's Avatar
what if i change the head to a 97+??</TD></TR></TABLE>
Looking at the block is the easiest way to check the year, especially since a 97 block will have a VIN on it, while a 94-95 will not. The BAR inspectors know what to look for, I am sure so many honda swaps have come through now, that they know exactly what markings on the head and block to look for in order to check the year.
Old Mar 29, 2006 | 12:40 PM
DC2 Mang's Avatar
you can also know the year by the first number in the serial number uner the block stamp
1xxxxx=94
2xxxxx=95
and so on
Old Mar 29, 2006 | 12:59 PM
hhmm ok thanx for the advice guys
Old Mar 29, 2006 | 01:33 PM
aeon's Avatar
i have a question also, I have a 96 gsr block, does the head and block have to be the same year? or can i use a 96+ gsr head?
Old Mar 29, 2006 | 01:35 PM
Lauj87's Avatar
humm...thats a good question...go ask a ref..:-D
Old Mar 29, 2006 | 01:46 PM
db8gsr_teg's Avatar
wtf why do you want to swap in a ls motor into a gsr?
Old Mar 29, 2006 | 01:49 PM
aeon's Avatar
Default Re: (db8gsr_teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8gsr_teg &raquo;</TD></TR><TR><TD CLASS="quote">wtf why do you want to swap in a ls motor into a gsr?</TD></TR></TABLE>
he has his reasons dude...
Old Mar 29, 2006 | 02:25 PM
Default Re: (aeon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeon &raquo;</TD></TR><TR><TD CLASS="quote">
he has his reasons dude...</TD></TR></TABLE>
thas riight......
Old Apr 1, 2006 | 02:16 PM
weak_sauce's Avatar
from what i heard, i believe you can only use the vtec head same year for your block (for instant, obd1 block can only use obd 1 vtec head, obd2 block can only use obd2 vtec head, pretty sure since obd2 head has more sensors than obd1 head. Unless you want to convert all the sensors and stuff over, since obd2 dizzy if differ than iobd1 dizzy, etc) they also check your ecu casing # IE p72 plus all the other number to make sure your motor is running the correct computer system. as long as the motor is swap in clean and it is legit and your ecu is for that motor you will be fine. it is not hard to get a BAR sticker and of course you will have to pass smog
1. Motor is same or newer than the vehicle
2. Clean swap, no lose wiring or any sort and motor is legit (not stolen)
3. Ecu is for the motor (same year or newer)
4. Has to pass smog
}-Black-Ls-Stunna-{
Sep 10, 2006 05:34 AM
EK79
Apr 10, 2006 02:07 PM
Ur 2 Slow 4 J
Sep 23, 2005 07:53 AM
95civickid
Jul 27, 2005 01:28 PM
B_CRUZ!
Apr 30, 2002 07:41 PM
