B16a1 Into a 94 Del Sol Help!!!!
Old May 28, 2004 | 04:56 PM
89-ef's Avatar
Default B16a1 Into a 94 Del Sol Help!!!!
I'm dropping a b16a1 with a cable tranny in a delsol. I'm buying the hasport cable conversion kit. I was wondering if i could use the stock b16 motor mounts or the d16 mounts or would i have to buy some after maket mount for this swap. there is a d16z6 in there right now. And would i use another wiring harness or can i use the harness on the d16? if i miss anything, go ahead and say something
thank..........
Old May 28, 2004 | 05:01 PM
nocturnaldragon's Avatar
Default Re: B16a1 Into a 94 Del Sol Help!!!! (89-ef)
This has been covered so many times b4 man, try searching!!!
Old May 28, 2004 | 07:21 PM
cinq's Avatar
check the hybrid section...and do a search...plenty of info there.
Old May 28, 2004 | 08:26 PM
hatchi's Avatar
you can use the z6 wiring but will have to change dist plug, alt, plug, inj. wires, also use the 94-00 integra mounts, the z6 upper driver and pass. top ones will work you will need to get 94-00 integra driverside mount bracket (one that bolts on the block. you will need to get delsol b series shift linkage
anzh86
Jul 22, 2010 01:50 PM
1990JDMCRX
24
Dec 29, 2009 12:56 PM
vtecspeed1320
Jan 23, 2006 11:14 AM
crxcess
Feb 12, 2003 05:16 AM
