4k Idle. B16A1. =(
Old May 28, 2004 | 04:56 PM
doublethink's Avatar
Default 4k Idle. B16A1. =(
The recipient car is a 1990 CRX DX.
I went to the wrong place to get this done. They rewired the car for the B16A1 with the SiR Harness. After almost a month of incompetence, I paid them just to get the car back.
It was throwing code 23, he didnt hook up the knock sensor. I did that, now its code free. When i start it, the rpms climb to 4k or so. I really am unsure what could be the cause. The throttle is closed.
Any clue what makes a car climb in rpms on its own?
Im really stumped. Im going over the helms and whatnot tomorrow.
Thanks for any help.
-Mike
Old May 28, 2004 | 05:01 PM
calgone47's Avatar
Default Re: 4k Idle. B16A1. =( (doublethink)
Double check all your vacuum lines, I think there's a diagram of them on hondaperf. If not I'm sure someone's posted it here before.
Old May 28, 2004 | 05:02 PM
kylefakesi-r's Avatar
how far did they get on the swap?
is coolant bled-that can cause erratic idle
is it timed right-that can cause incorrect idle
sounds strange but what throttle cable?
does the vacuum look like a retarded rat's nest?
info please.
Old May 28, 2004 | 05:08 PM
Default Re: 4k Idle. B16A1. =( (kylefakesi-r)
The vaccum is correct, I checked that with one of the b16 swap guides. The timing is alright. I think he used the stock throttle cable, its zip tied in there... Which is very sad but since its all the way shut I dont think its the problem here.
I install remote starts and alarms all day, i think i can handle this, but i need some help i guess.
Old May 28, 2004 | 05:20 PM
Bunger's Avatar
Where is the idle screw (in the TB) set?
Old May 28, 2004 | 05:26 PM
primeredbeast's Avatar
Default Re: 4k Idle. B16A1. =( (Bunger)
the throttle cable might not be adjusted right or it's probably a vacum problem
Old May 28, 2004 | 05:27 PM
Im sorry, that sounds promising but I do not know what that is!
Also this downpipe doesnt line up with my exhaust, is there anything i can do?
(its a stock exhaust)
Thanks so much for your replies!
-Mike
Old May 28, 2004 | 05:29 PM
Default Re: 4k Idle. B16A1. =( (primeredbeast)
alright, perhaps it is vaccum related. How should the throttle cable be adjusted?
I made sure its all the way closed when the pedal isnt being pushed, if theres more to it then that let me know.
Thanks!
Old May 28, 2004 | 05:40 PM
Nic's Avatar
Nic
Check the map sensors. Make sure the purge controls are pluged in. Make sure they are getting the vaccum from the correct ports.
Old May 28, 2004 | 05:42 PM
Default Re: (stk crx)
Ok will do.
ive seen in another post, if i don't care about emissions, what are the only mandatory things to hook up here. Im really digging for a solutions here.
Old May 28, 2004 | 08:19 PM
deftones0817's Avatar
Default Re: (doublethink)
FITV do a search for that that is probably ur problem.
DEF
cardinalboy07
Apr 13, 2012 06:44 AM
EJuno
Feb 5, 2008 06:20 PM
c0nspire
Feb 23, 2006 02:09 PM
jdm_rex
Jul 25, 2003 01:36 PM
TheHatchHog
May 15, 2003 10:01 PM
