b18a1 swap done just need to know something
Old May 28, 2004 | 04:43 PM
LisaCivic's Avatar
Default b18a1 swap done just need to know something
ok the vacuum lines on a b18a1 go to Fuel Pressure Regulator Control Solenoid Valve, Evap Purge Control Solenoid Valve, and MAP Sensor. My problem is that on a dx it only has 1 Control Solenoid Valve(do not know wich one) and a Map sensor. What do i do to get this to work propperly.
Old May 28, 2004 | 04:46 PM
kylefakesi-r's Avatar
Default Re: b18a1 swap done just need to know something (LisaCivic)
unplug the dx map unit and plug in the da integra one. the bracket mounts the same on the firewall and the connector is pinned out the same.
Old May 28, 2004 | 04:52 PM
LisaCivic's Avatar
Default Re: b18a1 swap done just need to know something (kylefakesi-r)
there is 2 more plugs on the integra
Old May 28, 2004 | 04:54 PM
huh? i am running a da map sensor on my b16...plugs were just fine.
Old May 28, 2004 | 05:03 PM
LisaCivic's Avatar
MAP will hook up, 2 wires go to another valve, the 2 wires that go to other valve, on dx on vlve does not hook up
Old May 29, 2004 | 11:47 PM
LisaCivic's Avatar
anyone who has a dx with b18a1 in have any pics of the engine bay right around the fire wall
CRXguy_88
Jul 11, 2010 09:10 PM
ylor4
Feb 19, 2009 06:28 PM
iainuts
Sep 20, 2008 10:23 AM
SandstormGT
Feb 13, 2005 08:09 PM
ImprtRcr02
Feb 26, 2004 06:34 PM
