How big is the fuel tank on CRX Si 1991?
I suspect a gas station cheating us, adding more gallons to their counter. I want to do something about it, but I want to be 100% sure. Does anybody know the size of a fuel tank for CRX Si, 1991?
Suzanna
Suzanna
The helms I have for an '88 says 11.9 US Gallons.
I'm assuming its the same for 91 as well, but someone correct me if I'm wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFSiR »</TD></TR><TR><TD CLASS="quote">got coilovers on? I do and my rear is higher. with me running out of gas, I still have 10 L left...
im guesing u mean 10 gallons?? cause my take is 30L
I almost don't want to believe it. I have records for the past 3 years, filling the tank when it started to go down to red. I always fit in something between 7.5 to 8 gallons, about the same milage driven between the fills (around 230 miles). Only a few times during these 3 years, at this "suspicious" gas station, I got in 8.75 to 9 gallons. Same mileage driven.
Suzanna
Suzanna
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sixftlion »</TD></TR><TR><TD CLASS="quote">I almost don't want to believe it. I have records for the past 3 years, filling the tank when it started to go down to red. I always fit in something between 7.5 to 8 gallons, about the same milage driven between the fills (around 230 miles). Only a few times during these 3 years, at this "suspicious" gas station, I got in 8.75 to 9 gallons. Same mileage driven.
Suzanna
If filling up after driving in red for couple days, I can get just about 9 gallons in.
Never any more than 9, though.
Suzanna
Suzanna
well its better to fill up after only using 8-9 gallons compared to 10-11.5 gallons...i usually fill up after 210 miles or 6 gallons...i dont want the sediments that might be in the fuel tank to go into my engine...
Suzanna
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator »</TD></TR><TR><TD CLASS="quote">
Isn't that what a fuel filter is for?
</TD></TR></TABLE>Isn't that what a fuel filter is for?
the fuel pickup is on the bottom of the tank anyways
</TD></TR></TABLE>the fuel pickup is on the bottom of the tank anyways
If you think station is reading gallons wrong, take a 5 gallon gas can and fill it up, see how much it says it is full
Then you know for sure if they are accurate or falsified. Just my 2cp worth
Of course I don't go there regularly, just a few times. But I thought I would do something about it, maybe let one of these TV channels to investigate it... that's bad if they really do it in purpose...
i've put 11 gallons in my crx. then again, i drive it till it starts "put-puttering".....fuel filter guys, just do it all when you get an oil change.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ceLtic »</TD></TR><TR><TD CLASS="quote">i've put 11 gallons in my crx. then again, i drive it till it starts "put-puttering".....fuel filter guys, just do it all when you get an oil change.
Are you saying change the fuel filter every 3000 miles?
</TD></TR></TABLE>Are you saying change the fuel filter every 3000 miles?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me »</TD></TR><TR><TD CLASS="quote">
Never any more than 9, though.</TD></TR></TABLE>
i just filled my tank last friday...and i got aprox. 11.115 gallons in the beast....i had to call someone to ask how many gallons the crx gas tank had....i was like "HOLY ****" cost me $22.00...
