Oxygen sensor question
Old May 28, 2004 | 03:25 PM
vtec69's Avatar
Default Oxygen sensor question
Would having a bad primary o2 sensor cause your car to fail emmisions in NY?
Cause i just got my car inspected and all I have done to it is intake, header, and high flow cat and I failed emissions.
Thanks In Advance
-Brian
Old May 28, 2004 | 04:46 PM
cjohnson_2's Avatar
Default Re: Oxygen sensor question (vtec69)
in a word, YES.
The Air fuel ratios will be messed up.
Old May 28, 2004 | 09:02 PM
vtec69's Avatar
Default Re: Oxygen sensor question (cjohnson_2)
yeah my co2 was like 2% higher than the limits and my hc was like 50 more than the limits
I just wanna make sure before i spend $100 on the o2 sensor that that will make me pass inspection
-Brian
Old May 29, 2004 | 04:30 AM
BigMoose's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec69 &raquo;</TD></TR><TR><TD CLASS="quote">yeah my co2 was like 2% higher than the limits and my hc was like 50 more than the limits </TD></TR></TABLE>
Sure thats not my CO was 2% higher, instead of CO2?
If the CO is high and the HC is high, you are running rich FWIW. Closed loop should have zeroed it in. Start with the O2 sensor and go from there. Otherwise it is a problem with the cat. Poisoned, cold, etc...
Old May 29, 2004 | 08:41 AM
vtec69's Avatar
Default Re: Oxygen sensor question (BigMoose)
well i dont think it has to do with the cat cause its only like a week old and its aftermarket.
I do get a CEL for the primary o2 but just wanna make sure thats the problem before i go out and fix it and find out it was something else
Old May 29, 2004 | 11:10 AM
mntuner2's Avatar
Also it didn't fail that bad to be a cat. It helps alot to drive the car for a half hour moderate-beat to get the motor real hot before you go to the emissions place. I also think you can retard your ignition a degree or two to get a little "cleaner"(lower HC) burn.?. I think.
Old May 29, 2004 | 10:19 PM
vtec69's Avatar
Default Re: Oxygen sensor question (mntuner2)
O BTW its a subaru impreza and i wouldnt even know how to mess with the timing cause i dont think it has a dizzy
Old May 31, 2004 | 04:51 PM
mntuner2's Avatar
You mess with the crank/cam sensor.
Old May 31, 2004 | 06:55 PM
vtec69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mntuner2 &raquo;</TD></TR><TR><TD CLASS="quote">You mess with the crank/cam sensor.</TD></TR></TABLE>
Nope never touched that at all
Old May 31, 2004 | 10:58 PM
tjohnson329's Avatar
did you say you failed emissions in New York. Cause if so you can't, NY doesn't do emissions the next state close to us that does emissions is NJ. you might be getting scammed into getting your car worked on when it doesn't need to be. check it out BUT NO EMISSIONS IN NY
Old Jun 1, 2004 | 11:06 AM
vtec69's Avatar
Default Re: Oxygen sensor question (tjohnson329)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tjohnson329 &raquo;</TD></TR><TR><TD CLASS="quote">did you say you failed emissions in New York. Cause if so you can't, NY doesn't do emissions the next state close to us that does emissions is NJ. you might be getting scammed into getting your car worked on when it doesn't need to be. check it out BUT NO EMISSIONS IN NY</TD></TR></TABLE>
umm yeah there are emissions in NY.
Not all parts but Long Island there is
Old Jun 2, 2004 | 03:21 PM
vtec69's Avatar
bump
Old Jun 5, 2004 | 11:24 AM
vtec69's Avatar
ramboPandA
Sep 16, 2015 04:57 PM
Mad-Mike
Jun 6, 2010 08:58 PM
sohc vtec rex
Mar 18, 2008 01:16 PM
Coltmorris
Oct 27, 2006 01:29 PM
13link EG
Oct 13, 2004 09:18 PM
