how much hp does a ls vtec
Old May 28, 2004 | 01:53 PM
prcrx124's Avatar
Default how much hp does a ls vtec
hey am putting together a ls vtec motor and i was thinking how much hp and torque will it make i have a 97 block with a 01 gsr head
Old May 28, 2004 | 02:04 PM
crx_88_si's Avatar
Default Re: how much hp does a ls vtec (prcrx124)
a hair less then a gsr (due to lower compression)
again, different cams (b16, b17, gsr, CTR, ITR) all play a roll here. as well as TB and intake manifold etc.. but about GSR power.
Old May 28, 2004 | 03:54 PM
prcrx124's Avatar
Default Re: how much hp does a ls vtec (crx_88_si)
SO DO U KNOW HOW MUCH HP WILL IT MAKE
Old May 28, 2004 | 04:00 PM
Mr_CRX's Avatar
He just answered your question.
Every LS-Vtec build is different. If you just slap the head on the block, it will have compresion in the 9's and be similar in hp to a GSR.
There are countless variations and combinations of parts to be used in this build. If you want an exact number, we can't give that to you, because an LS-Vtec isnt a motor form the honda factory with a given rating.
By the way, turn your CAPS LOCK off.
Old Jun 1, 2004 | 07:24 PM
prcrx124's Avatar
Default Re: how much hp does a ls vtec (Mr_CRX)
am just putting the head on and some nos in it for now
Old Jun 1, 2004 | 07:41 PM
LSVTEC 91 Civic's Avatar
Banned
This is my dyno sheet.
Hopefully you're putting Nitrous Oxide in your engine, and not an acronym for a brand.
Old Jun 1, 2004 | 07:47 PM
ExplicitSpeed's Avatar
He is right it all varries, each setup is different but rough estimate, depending on what kinda bolt ons also.
9-1 compression 160+whp
11-1 compression 180+whp
Old Jun 1, 2004 | 09:03 PM
kshymkiw83's Avatar
Default Re: how much hp does a ls vtec (ExplicitSpeed)
with your setup you should run EXACTLY 167.7 hp and 109.3tq these numbers are EXACT and is EXACTLY what numbers you will put down
Old Jun 1, 2004 | 10:47 PM
hahahahhah's Avatar
Default Re: how much hp does a ls vtec (kshymkiw83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kshymkiw83 &raquo;</TD></TR><TR><TD CLASS="quote">with your setup you should run EXACTLY 167.7 hp and 109.3tq these numbers are EXACT and is EXACTLY what numbers you will put down </TD></TR></TABLE>
hahahah
Old Jun 3, 2004 | 07:58 AM
prcrx124's Avatar
alot of poeple telling me that ill have close to 200 hp n 175whp i dont know if thatz true so ill find out when i go to the dyno
Old Jun 3, 2004 | 09:02 AM
Overkill's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prcrx124 &raquo;</TD></TR><TR><TD CLASS="quote">SO DO U KNOW HOW MUCH HP WILL IT MAKE </TD></TR></TABLE>
Your a dumbass. Theres no way to find out EXACTLY what your car will make. No reason for you to be a dick to a guy that instead of flaming u for ur stupidity was helping u out.
Old Jun 3, 2004 | 09:04 AM
I3ackfire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prcrx124 &raquo;</TD></TR><TR><TD CLASS="quote">alot of poeple telling me that ill have close to 200 hp n 175whp i dont know if thatz true so ill find out when i go to the dyno</TD></TR></TABLE>
Make new friends
Old Jun 3, 2004 | 09:18 AM
keithv's Avatar
Default Re: how much hp does a ls vtec (I3ackfire)
Like everyone else said, the power output will vary. There is no correct answer.
ser13
Apr 15, 2008 07:46 AM
LILSOWEK
Aug 21, 2006 09:03 PM
na200whpteg
Sep 26, 2004 07:51 PM
DsBananas94LS
Aug 30, 2004 08:26 PM
dAndOg130
Oct 8, 2003 11:37 AM
