help me installing this timing belt drive pulley
Old May 28, 2004 | 01:45 PM
VWkila's Avatar
Default help me installing this timing belt drive pulley
It's #13. I've tried hammering, it dosen't budge...
Old May 28, 2004 | 02:25 PM
dot this Promo's Avatar
Default Re: help me installing this timing belt drive pulley (VWkila)
you need a gear puller
Old May 28, 2004 | 02:27 PM
99blackcivicSi's Avatar
Default Re: help me installing this timing belt drive pulley (jsb18b)
i have never had a problem w/ them coming off, wierd get a puller
Old May 28, 2004 | 03:38 PM
VWkila's Avatar
Default Re: help me installing this timing belt drive pulley (99blackcivicSi)
Thanks for the reply... My question was rather on INSTALLING though...
And I never had problem getting off either.
Old May 28, 2004 | 06:39 PM
VWkila's Avatar
ttt
Old May 28, 2004 | 08:23 PM
hatchi's Avatar
doesnt it have a groove to go on there?? try wiggling it back and forth
Old May 29, 2004 | 03:13 AM
VWkila's Avatar
Default Re: help me installing this timing belt drive pulley (hatchi)
this thing is VERY tight. Wiggling dosen't work.
Old May 29, 2004 | 04:30 AM
b-powa's Avatar
try getting all dirt off
Old May 29, 2004 | 05:01 AM
VWkila's Avatar
Default Re: help me installing this timing belt drive pulley (b-powa)
The pulley should slide in right? It's not like it's pressed fit, I don't think.
Old May 29, 2004 | 06:33 AM
4DRPIMPIN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VWkila &raquo;</TD></TR><TR><TD CLASS="quote">The pulley should slide in right? It's not like it's pressed fit, I don't think. </TD></TR></TABLE>
It's not pressed in. It's just been there for a while. Try to wiggle it side to side, take a rubber mallet and tap it. If your trying to put it on try a little bit of oil, should slide on. Theres only one way to install it b/c of the groove on the crank.
Old May 29, 2004 | 07:43 AM
xerox445's Avatar
Default Re: help me installing this timing belt drive pulley (4DRPIMPIN)
Is that the one with the little "key" in it? Thats a bioch to get off, very tight, i would imagine it would take some work to get it back on
Old May 29, 2004 | 12:52 PM
VWkila's Avatar
Default Re: help me installing this timing belt drive pulley (xerox445)
Okay, I did manage to get it on. This is the full story...
I took this pulley off last November, when I started to rebuild this motor. When I took it off, I had NO trouble whatsoever.
When I tried to put it back on last night, it wouldn't go in very easily, so I used a hammer and a block of wood to put it on half way.
But half way in, it would not budge anymore. So I used a gear puller to pull it back out. This morning , I tried it again. This time, I used some oil to lube it up.
Again, it did not move freely, even with a hammer and a block of wood. But when it got to a certain point, it just poped in!
crvglenn
Honda CR-V & Element
Aug 20, 2017 01:44 AM
hmtcrxsir
18
Dec 6, 2014 03:17 AM
92sleeperh22a4
Oct 18, 2007 02:23 PM
EG2Driver
Jun 15, 2006 07:24 PM
