conversion harnesses for obd0-obd1.... what ones do i need???? was i told wrong???
Old May 28, 2004 | 01:29 PM
CRX_GUY_123's Avatar
Default conversion harnesses for obd0-obd1.... what ones do i need???? was i told wrong???
hey i have a 93 ls motor im putting in my 89 crx si and someone told me i need 2 conversion harnesses... 1 for the ecu and one for under the hood... i got the one for the ecu but what about under the hood??? what do i need for that?? and do i even need it or what...?? let me know... thanks...
Old May 28, 2004 | 01:37 PM
Colin's Avatar
Default Re: conversion harnesses for obd0-obd1.... what ones do i need???? was i told wrong??? (CRX_GUY_123)
your question was answered last time you posted this: https://honda-tech.com/zerothread?id=862718
you only need the jumper harness at the ecu.
For the distributor you simply change the plastic connectors (commonly referred to as "plugs") so that you can plug your obd0 engine harness (off of the si motor) into the obd1 distributor (from the ls motor).
Old May 28, 2004 | 01:40 PM
96-EJ6 B18C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_GUY_123 &raquo;</TD></TR><TR><TD CLASS="quote">hey i have a 93 ls motor im putting in my 89 crx si and someone told me i need 2 conversion harnesses... 1 for the ecu and one for under the hood... i got the one for the ecu but what about under the hood??? what do i need for that?? and do i even need it or what...?? let me know... thanks... </TD></TR></TABLE>
you need this one...
http://www.boomslang.us/obd0.htm
Old May 29, 2004 | 04:11 AM
NCchris's Avatar
This has been covered, but, for the cost of the harness, buy a 90-91 Teg distributor, a 90-91 PR4 ecu, use 88-91 CRX/Civic injectors with your stock resistor box and run the engine as OBD0. Your stock engine harness will work with only minor mods and everything is plug and play. Search, there is lots of info here.
HTH
chris
Old May 29, 2004 | 05:14 AM
crx_88_si's Avatar
or you could get a 90-91 teg Dist and ECU
Old May 29, 2004 | 05:53 AM
EG8R's Avatar
Default Re: (crx_88_si)
Those harnesses are expensive. I paid 150 CDN for mine.... So thats about 1000 bux US or so.... Dddddddaaaaaaaaaaammmmmmmmmmmm
Old May 29, 2004 | 06:10 AM
NCchris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">or you could get a 90-91 teg Dist and ECU</TD></TR></TABLE>
yeah, what he said
chris
Old May 29, 2004 | 07:01 AM
slywfbpsi's Avatar
Default Re: (skelly ed666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skelly ed666 &raquo;</TD></TR><TR><TD CLASS="quote">Those harnesses are expensive. I paid 150 CDN for mine.... So thats about 1000 bux US or so.... Dddddddaaaaaaaaaaammmmmmmmmmmm</TD></TR></TABLE> the harness shouldn't cost you anymore than 160 for blown90hatch's harness.
BubbaDeuces
Feb 18, 2009 12:57 PM
type Gendy
May 9, 2005 12:04 PM
93slmdcvcsi
Aug 6, 2004 08:32 AM
BB6-213
Jun 22, 2004 12:01 AM
Malachi_
14
Sep 25, 2003 04:12 PM
