Problem with JDM Itr HID's
Old May 27, 2004 | 10:18 PM
crazyitr's Avatar
Default Problem with JDM Itr HID's
Allright I have done a search.
I can get all the lights in my headlamp assembly to work except the low beam hid's.
If I put power to the white wire (middle spade connector) in the 5 pin plug I get a buzzing sound from the ballast, but no light.
I have tried grounding the black wire to the chassis thinking that I might have a bad ground. That has not worked either.
Both right and left headlamps are doing the same thing
Any ideas.
I need to determine if the hid's work or I need to send them back to the place that I bought them
Yes I have seen the post with a schematic of the wiring.
Again all the other lights in the headlamp work
What else might be wrong
Old May 31, 2004 | 02:04 PM
nitrous137's Avatar
Default Re: Problem with JDM Itr HID's (crazyitr)
Hello
I'm doing a HID in a 94 integra....did you get your HID working? if so mail me the wires that you made it work....did you buy any relays????
thanks
mail me asap
Old May 31, 2004 | 10:18 PM
Pootie's Avatar
when i got my lamps in i tested them with a battery.....grounded the black wire and touched the other wires individually to power....that's how i checked to see if all of my bulbs worked....if you hear your ballast buzzing then i can only assume maybe it's the bulb?....and sorry to jack your thread but for the people who installed hid's on 94-97 tegs, how did u fit it with the abs module right there?
_EF9
Lighting
Nov 25, 2012 05:58 PM
dc2acgsr99
Lighting
Oct 22, 2007 03:19 PM
b16hybridsol
Sep 25, 2004 01:45 AM
crazyitr
May 28, 2004 05:16 AM
