Speedometer Problem
Old May 27, 2004 | 07:03 PM
dvsluder's Avatar
Default Speedometer Problem
Hi, new to the board. Need some help.
My speedometer started failing some time ago. It would jump to 20 mph and shake a little around it when I drive slow, then just stay there when I speed up. It recovers sometimes and shows the right speed. If I kick the daily miles reset button a few times, it starts working occasionally. It also often kicks in when I drive longer on a highway. Is this the speedometer, the wiring or the speed sensor?
Old May 27, 2004 | 11:34 PM
.bagged's Avatar
Default Re: Speedometer Problem (theunknownn)
could be either. I would check all of your fuses and then go to the grounds. If you can jiggle things and you get reaction then it sounds like a loose connection somewhere
Old May 28, 2004 | 05:42 AM
Mike813's Avatar
Default Re: Speedometer Problem (bagged93accord)
if its not a loose wiring, it could be your VSS, and if not that just your speedo's f*ed like mine did...
Matthew98DX
11
Oct 26, 2014 07:55 PM
vedha
Oct 9, 2009 09:46 PM
doubleoazn03
Sep 5, 2008 10:33 PM
vtNaMeSe
Jun 21, 2003 06:55 AM
gatoracer
Jan 14, 2003 05:52 PM
