LS swap
i have a obd0 91 hatch im putting in a obd1 92 ls engine
i have the dizzy and ecu from a obd0 91 ls so they are compatible iwth the civic harness
is there any other sensors or connections that my civic engine harness wont plug into ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACINTWEEK »</TD></TR><TR><TD CLASS="quote">i have a obd0 91 hatch im putting in a obd1 92 ls engine
is there any other sensors or connections that my civic engine harness wont plug into ? </TD></TR></TABLE>
This post should help you somewhat: https://honda-tech.com/zerothread?id=864302
by the info in that post it seems i have everything i need(except the patience to do the dpfi-mpfi conv)
i'm bout to get started on this thing and wanted to make sure i had everything i need
the injectors aint gonna work, or if they will it needs to be modified. you got obd 1 injectors which cant be run by the obd0 ecu.
if they can be modified idk how modify it, maybe someone else can help. but if they cant be modified then you gotta get 90-91 injectors with a resistor box
mauibuilt
Aug 4, 2005 01:10 PM
fatrhino
Feb 23, 2004 01:32 AM
