CKP (Crankshaft positioning sensor) Location????
FIXED!!!!!!!!!!!!!!!!!!!!
Chris
Modified by RockstarJR at 12:27 PM 6/1/2004
Modified by RockstarJR at 4:16 PM 7/26/2004
Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockstarJR »</TD></TR><TR><TD CLASS="quote">the sensor is behind the crank pulley and lower timing cover- replaced and still nothing changed</TD></TR></TABLE>
What? The CKP, CYP, and TDC sensors are all in the distributor. What kind of sensor is behind the crank pulley?
The sensor behind the pulley is the crankshaft SPEED sensor. Make sure the connections were clean when reconnecting and that there is no wear on any of the wires along the timing belt.
Could this also be from wiring in the ecu? We re-soddered the wires after removing my vafc... If I cannot fix this, I am going to have to have the car towed to a friend's shop.
Modified by RockstarJR at 12:27 PM 6/1/2004</TD></TR></TABLE>
yes. VAFC gets its RPM signal from the CKP sensor. if you HaXoRd up that wire and didn't connect it... i'd have to say that is your problem. check that before you go dumping money on a bunch of other crap that you don't need to replace.
Rickmanalex
Aug 31, 2014 07:45 PM
xwhitchx
May 27, 2009 05:55 PM
who00knows
Jan 14, 2003 10:32 AM
1993, 92, ckp, crank, crankshaft, cw, cyp, distributor, fluctuation, honda, itr, location, postioning, prelude, sensor, speed, tdc
