crank sensor? how to replace?
Old Apr 17, 2003 | 05:57 AM
sailor's Avatar
Default crank sensor? how to replace?
anyone know how to replace the tdc/crank sensor inside the timing cover? 97accord 2.2lx motor? whats involved?
Old Apr 17, 2003 | 05:59 AM
psi420's Avatar
Default Re: crank sensor? how to replace? (sailor)
You need to take the crank pulley off.
There is a small magnet looking sensor that reads the timing gear .
Old Apr 17, 2003 | 06:32 AM
Spade's Avatar
Default Re: crank sensor? how to replace? (psi420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psi420 &raquo;</TD></TR><TR><TD CLASS="quote">You need to take the crank pulley off.
There is a small magnet looking sensor that reads the timing gear .</TD></TR></TABLE>
Correct. But, before you do that make sure the alternator belt didn't cut the wires to it. Happened to me.
Old Apr 17, 2003 | 08:23 AM
Stripped Honda's Avatar
99-0104
Default Re: crank sensor? how to replace? (Spade)
if you need one i got one from a 96 gsr let me know
Natie Barnard
Honda CR-V & Element
Jan 16, 2019 06:38 AM
tougeem2
Nov 15, 2011 05:39 AM
kndj30
Honda Civic (2001 - 2005)
Feb 11, 2010 03:58 AM
xwhitchx
May 27, 2009 05:55 PM
lude98SH
Dec 27, 2007 10:32 AM
