B20B VTEC QUESTIONS
Old May 26, 2004 | 09:35 PM
michaelduvall's Avatar
Default B20B VTEC QUESTIONS
Hey, I am about to buy a B20 long block and a B18C1 head to put on it. What I was wondering was what tranny should I use? I can get a B18A/B/C or a B16A, I was thinking of going with just the B18A/B because its the cheapest. What would you recomend I should buy? and whats the differences in the trannys? Thanks. Also anyone else out there done this swap have any HP figures? Thanks
Old May 26, 2004 | 10:20 PM
Kataku2K3's Avatar
Default Re: B20B VTEC QUESTIONS (michaelduvall)
Do not use a nonVTEC tranny, you'll totally defeat the purpose of doing the swap. Just think, a straight LS motor revs to ~6800rpm and has a 1st gear that will allow you ~35mph, a VTEC motor is setup with a tranny to do the same mph in 1st but at 1200-1600rpm higher. Only thing it's good for is a low rpm cruise on the freeway but if you want that just toss a LS 5th in a VTEC tranny. We don't even use nonVTEC trannies on our high boost turbo cars. Go with a GSR, ITR, or 2000 Si tranny.
Old May 28, 2004 | 08:10 AM
Ekasey's Avatar
Default Re: B20B VTEC QUESTIONS (Kataku2K3)
agreed with above
i had a b20 vtec setup
b20b block all stock
b16 head with type r manifold, type R cams, and springs, dc 4-1 header
Car produced 182 on 91 octane after v-afc tuning
Old May 28, 2004 | 01:26 PM
3rdGteg's Avatar
Default Re: B20B VTEC QUESTIONS (eLusive ek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">agreed with above
Car produced 182 on 91 octane after v-afc tuning</TD></TR></TABLE>182whp with just bolt-ons
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelduvall &raquo;</TD></TR><TR><TD CLASS="quote">Hey, I am about to buy a B20 long block and a B18C1 head to put on it. What I was wondering was what tranny should I use? I can get a B18A/B/C or a B16A, I was thinking of going with just the B18A/B because its the cheapest. What would you recomend I should buy? and whats the differences in the trannys? Thanks. Also anyone else out there done this swap have any HP figures? Thanks</TD></TR></TABLE>get a vtec tranny like kataku2k3 said.
Drsexiestboy
19
Oct 25, 2011 12:57 PM
JDMJAYDC2
Apr 9, 2007 07:48 PM
eathatch94
37
Jul 7, 2004 11:08 PM
cornholioEK
Apr 15, 2003 12:41 AM
kmf0211
Jul 16, 2002 11:06 AM
