please help with timing???
Old May 26, 2004 | 04:46 PM
mini-v-si's Avatar
Default please help with timing???
well parked my car in drive way, next thing came back to start the car and the car stated right away but ten seconds later it died and I did once more, same thing happpend. but after a couple of time it didn't start anymore. Check the timing and it looks like timming jumped a tooth, timming was a little loose. Could any other damage be add on to this situatino??? li ke a bent valves???
Old May 26, 2004 | 08:01 PM
Master Tech's Avatar
Default Re: please help with timing??? (94tegGSR)
If you were parked and at low rpms most likely no
If you want to be sure remove valve cover remove cams , remove plugs & add air presure (80 psi minimun and see if you hear it leak out . carefull the crank WILL JUMP! If no air scapes they are Ok.
Regards Joe Sr
Old May 27, 2004 | 12:07 AM
mr. carpenter's Avatar
Default Re: please help with timing??? (Master Tech)
sounds more like a fuel problem or distributor.
Old May 27, 2004 | 05:46 AM
oz#227's Avatar
New User
It would have to jump about 4 or more teeth to hit something.
Old May 27, 2004 | 05:50 AM
tilt's Avatar
ive ran a car with it being off a tooth.
also a timing belt snapped on my d15b2 when my friend used to own it. took the head off and there was no sign of valve to piston contact.
Old May 27, 2004 | 06:21 AM
91civicDXdude's Avatar
if you look on the front of the engine (side), there is a small wheel. its called the timing belt tensioner. tighten it up dummy.
Old May 30, 2004 | 07:36 PM
mini-v-si's Avatar
Default Re: (91civicDXdude)
yeah I know. but yeah checked everything and now finally found the problem. It was a bad fuel pump.
B18b Axles
Jul 20, 2013 07:08 PM
James89DX
Honda Civic (2001 - 2005)
Jun 24, 2012 05:20 PM
surrealx
Jul 10, 2010 07:52 PM
young geezer
May 21, 2009 08:37 AM
Ultraspeed DC2
Mar 29, 2008 07:59 AM
