LEAKING CLUTCH FLUID :(
Old May 26, 2004 | 04:07 PM
9deuce9rr's Avatar
Default LEAKING CLUTCH FLUID :(
about 2 weeks ago, outta nowhere my car was just about out of clutch fluid. I filled it up 4 days ago and today it was completely out, i barely made it home. As soon as i got home i filled it up and then traced the lines but couldn't find any leaks anywhere.
anybody with any experience or ideas on this? would be greatly appreciated
Old May 26, 2004 | 04:14 PM
94Vtecluder's Avatar
Default Re: LEAKING CLUTCH FLUID :( (WhiteLude)
Either your master or slave cylinder is shot, have them looked at.
Old May 26, 2004 | 04:24 PM
9deuce9rr's Avatar
Default Re: LEAKING CLUTCH FLUID :( (94Vtecluder)
what do you mean by shot?
Old May 26, 2004 | 04:25 PM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteLude &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean by shot? </TD></TR></TABLE>
Broken, I would assume.
Get them replaced.
Old May 26, 2004 | 04:50 PM
junbb1's Avatar
Default Re: LEAKING CLUTCH FLUID :( (-Bionic-)
your clutch master cyl. is probably leaking. it is a good idea to replace your slave cylinder at the same time.
you may also have a leak on the rubber line that stretches accross your transmission. i have replaced this line on my 94 lude.
to check your master cylinder look at the clutch pedal arm under your dash. you will see the rod from the master cyl. Look around the rod and you should see brrake fluid leaking down from it.
the rubber line over the tranny will not have a drip but rather a moist spot on the line. it wont look major at all but trust me it will cause your pedal to go dead.
also check your feed line from the resovoir to the master. i replaced that also.
i have also replaced the clutch damper due to leaking. it is on the left side frame under the abs modulator, and intake arm.
Old May 26, 2004 | 09:47 PM
9deuce9rr's Avatar
Default Re: LEAKING CLUTCH FLUID :( (junbb1)
right on, i'll check all that after school tomorrow, thanks for the info
Old May 27, 2004 | 04:30 PM
gen4vteclude's Avatar
Check the clutch master cylinder from inside the car, mine went that way and was leaking fluid into the passenger compartment
Old May 28, 2004 | 05:54 PM
PetroGuyX's Avatar
mine went on christmas eve, sucked horribley, definitely replace those two things and don't wait too long because eventually you'll have to replace your clutch... which i also had to do
Old May 28, 2004 | 11:28 PM
9deuce9rr's Avatar
Default Re: (PetroGuyX)
found the leak, it was in the hose above the tranny.... mine however isn't "moist" it is SOAKED lol looks like i know wut i'll be doing this weekend
jajackson
Nov 16, 2007 08:50 AM
7sins
Aug 24, 2006 11:06 PM
mike93boost
Feb 23, 2006 08:37 PM
Brownjd
May 31, 2005 03:27 PM
UA6 BALLER STATUS
Dec 26, 2004 01:22 PM
