Valve Guides!
Old May 26, 2004 | 10:52 AM
S88HON's Avatar
Default Valve Guides!
Hi again!
Can anybody explain the process of removing the old valve guides froma B18 head? I have bronze ones at the ready, but curious on how the old ones come out.. Is it really labour intensive?
Thanks
Andrew
Old May 26, 2004 | 01:37 PM
non-VTEC's Avatar
Default Re: Valve Guides! (S88HON)
you need to bring the head to a good machine shop to have the guides replaced. they need to be pressed out with a hydrolic press and the new ones pressed in.
there is also a spec on how far in the guides need to be pressed into the head which is why a good machine shop who has worked with honda head before should have no trouble doing this for you.
good luck
Old May 27, 2004 | 11:48 AM
Rocket's Avatar
Default Re: Valve Guides! (non-VTEC)
It's explained in the helms manaul. Ask your machinist if they can do it.
You'll also need to do a valve job after the guides are replaced.
dominate9
Apr 14, 2020 02:10 PM
JDMDC4life
Jul 20, 2014 11:58 AM
JDM turbo DC
Jan 30, 2007 01:31 AM
biggie2005
Feb 26, 2004 06:23 PM
fe519
Dec 27, 2002 12:50 PM
