PUMPING BETTER FUEL
I have a 96' Civic Coupe with a b18c5 swap. I rebuilt the head and block and installed the drag bolt-on turbo kit(stage 2). My first question is with the hp I have, will a stage two clutch kit be enough, or do I need more. If so, what company do you suggest?
The second question is about aftermarket fuel pumps. I'm a little naive in this area, so that's why I'm writing sending this out. what brand will work best with my setup? And if I change the fuel pump, should I change the fuel lines as well? Thanks
I would suggest a stronger clutch. Your not going to be driving normal obviously.
And
Aftermarket pumps are all Walbro they just get re-badged
You will not need to change your fuel lines.
And
madcrx69
Aug 15, 2017 09:26 PM
