Im not getting any fuel, what the heck??
when i try to start the car for the first time of the day it starts and stalls from no fuel. if i spray in the intake manifold it starts up and then stalls cuz no fuel. i am not getting any pressure at the fuel filter. is there like a fuse or a relay i should be looking for? the fuel pump was working a few days ago. thanks in advance
car - 92 civic dx, previous automatic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotor.net »</TD></TR><TR><TD CLASS="quote">
car - 92 civic dx, previous automatic</TD></TR></TABLE>
Is the pump not working now? Can you hear it prime?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotor.net »</TD></TR><TR><TD CLASS="quote">it gets power to the pump i know that. where should i be listening to?</TD></TR></TABLE>
Just turn your ignition switch to ON. Don't start it. Listen to the back seat. If you hear it hum then click off after a few seconds that's not the problem. If you don't hear anything then you know what the problem is. But check your fuse before changing the pump if need be.
Whats the mileage on the fuel pump and fuel filter. Also what kind of injectors are you running? If you have high mileage on your fuel pump, it may need to be replaced or upgraded, same goes with your fuel filter, since it tends to clog with high miles. These parts are fairly cheap and easy to install.
edit: assuming that your fuel pump is priming this could be the problem.
When you turn your key to the on position the fuel pump should turn on pressurizing the system. If you roll your windows down you should be able to hear the pump turn on. If you don't then something is wrong. I believe there is a relay that controls this function but I'm not sure...
Good luck
Edit: Wow...the two above posts came in whis I was typing mine...but I'm leaving it anyway.
Good luck
My fuel pump worked one day and then died later in the afternoon.
Like everyone said. Listen to see if the fuel pump is priming when you turn your key to the on position.
When my fuel pump was dieing it was hard to turn the car on. It would come one and die in seconds or less.
Then when it was warmed up the car ran fine.
if its not then you will have to go through a whole shitload of pgm-i testing or you can bite the bullet and assume your pump is dead and replace it. But I would say thats a last ditch effort. I almost bought a new fuel pump and found out I hit a kill switch to it I didnt even know was installed in my car.
ok i have determined that the fuel pump primes some times but not all. i can turn the key to on position on and off like 10 times and it will prime only a couple out of the 10. i also noticed that even sometimes when i hear it prime it still does not start. when turning the key to the on position i noticed the system will stop priming when the check engine light goes out. you can hear the priming like turn off when that light goes out. the car has about 100k miles and the motor setup like 75k. wheres the fuses i should be checking, in the fuse panel under dash or hood. and what would the relay say on it, i saw a bunch near the underdash fusebox. thanks
Dont bother messing with any fuses. if a fuse was blown it would never prime. I dont even know if there is a relay for the pump, generally the cover of your relay box will have a diagram telling you what each relay controls.
I bet if your fuel pump isn't priming that its your PGM-FI main relay.
here you go:
https://honda-tech.com/zerothre...36514
here you go:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">I bet if your fuel pump isn't priming that its your PGM-FI main relay.
here you go:
thanks alot for the site. ill go check out the car and see whats up
here you go:
</TD></TR></TABLE>thanks alot for the site. ill go check out the car and see whats up
lgn1281
Oct 14, 2005 08:26 AM
