Im not getting any fuel, what the heck??
Old 05-26-2004, 07:57 AM
allmotor.net's Avatar
Default Im not getting any fuel, what the heck??
when i try to start the car for the first time of the day it starts and stalls from no fuel. if i spray in the intake manifold it starts up and then stalls cuz no fuel. i am not getting any pressure at the fuel filter. is there like a fuse or a relay i should be looking for? the fuel pump was working a few days ago. thanks in advance
car - 92 civic dx, previous automatic
Old 05-26-2004, 07:59 AM
AutoXer's Avatar
Default Re: Im not getting any fuel, what the heck?? (allmotor.net)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotor.net &raquo;</TD></TR><TR><TD CLASS="quote">
car - 92 civic dx, previous automatic</TD></TR></TABLE>
Is the pump not working now? Can you hear it prime?
Old 05-26-2004, 08:01 AM
Default Re: Im not getting any fuel, what the heck?? (EX_AutoXer)
it gets power to the pump i know that. where should i be listening to?
boredracer408's Avatar
If you can't hear it prime check your fuses and fuel pump connections...
Old 05-26-2004, 08:07 AM
JimmyAtlantis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotor.net &raquo;</TD></TR><TR><TD CLASS="quote">it gets power to the pump i know that. where should i be listening to?</TD></TR></TABLE>
Just turn your ignition switch to ON. Don't start it. Listen to the back seat. If you hear it hum then click off after a few seconds that's not the problem. If you don't hear anything then you know what the problem is. But check your fuse before changing the pump if need be.
el diablo
Built to Spill's Avatar
Whats the mileage on the fuel pump and fuel filter. Also what kind of injectors are you running? If you have high mileage on your fuel pump, it may need to be replaced or upgraded, same goes with your fuel filter, since it tends to clog with high miles. These parts are fairly cheap and easy to install.
edit: assuming that your fuel pump is priming this could be the problem.
Old 05-26-2004, 08:09 AM
axhandler's Avatar
When you turn your key to the on position the fuel pump should turn on pressurizing the system. If you roll your windows down you should be able to hear the pump turn on. If you don't then something is wrong. I believe there is a relay that controls this function but I'm not sure...
Good luck
Edit: Wow...the two above posts came in whis I was typing mine...but I'm leaving it anyway.
Old 05-26-2004, 08:54 AM
HyBriDcxR's Avatar
My fuel pump worked one day and then died later in the afternoon.
Like everyone said. Listen to see if the fuel pump is priming when you turn your key to the on position.
When my fuel pump was dieing it was hard to turn the car on. It would come one and die in seconds or less.
Then when it was warmed up the car ran fine.
Old 05-26-2004, 08:56 AM
137's Avatar
Default Re: Im not getting any fuel, what the heck?? (HyBriDcxR)
if its not then you will have to go through a whole shitload of pgm-i testing or you can bite the bullet and assume your pump is dead and replace it. But I would say thats a last ditch effort. I almost bought a new fuel pump and found out I hit a kill switch to it I didnt even know was installed in my car.
Old 06-03-2004, 06:54 AM
ok i have determined that the fuel pump primes some times but not all. i can turn the key to on position on and off like 10 times and it will prime only a couple out of the 10. i also noticed that even sometimes when i hear it prime it still does not start. when turning the key to the on position i noticed the system will stop priming when the check engine light goes out. you can hear the priming like turn off when that light goes out. the car has about 100k miles and the motor setup like 75k. wheres the fuses i should be checking, in the fuse panel under dash or hood. and what would the relay say on it, i saw a bunch near the underdash fusebox. thanks
Old 06-07-2004, 11:20 PM
I'll cut ya!'s Avatar
Dont bother messing with any fuses. if a fuse was blown it would never prime. I dont even know if there is a relay for the pump, generally the cover of your relay box will have a diagram telling you what each relay controls.
Old 06-07-2004, 11:32 PM
dantastic's Avatar
sounds like the classic main relay problem to me, causing interrmittant failure of the fuel pump
Old 06-07-2004, 11:35 PM
Default Re: (dantastic)
thats what im thinking, what is the main raly labeled as and what color is it usually. 92 civic dx auto chassis. thank you
Old 06-20-2004, 07:58 PM
Default Re: (allmotor.net)
can anyone tell me where it is? thanks
Old 06-20-2004, 08:37 PM
Global Moderator
Jimmy's Avatar
I bet if your fuel pump isn't priming that its your PGM-FI main relay.
here you go:
https://honda-tech.com/zerothre...36514
Old 06-20-2004, 09:28 PM
96MidoriHatch's Avatar
there is relay for the fuel pump, not sure if thats your problem or not, but i am definetly sure there is a relay as this was the problem on my buddy's civic a few weeks ago
Old 06-21-2004, 04:45 AM
Default Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">I bet if your fuel pump isn't priming that its your PGM-FI main relay.
here you go:
thanks alot for the site. ill go check out the car and see whats up
o0ohaviko0o
11-25-2007 11:18 AM
SuperSteve737
05-29-2006 01:39 PM
lgn1281
10-14-2005 08:26 AM
dEtSoOb
07-12-2005 06:08 PM
someforlight
10
03-30-2005 03:30 PM
Quick Reply: Im not getting any fuel, what the heck??
