Flamer Kit installation problem
Old May 26, 2004 | 04:42 AM
Kream's Avatar
Default Flamer Kit installation problem
Hi there,I have a 1997 honda civic 1.8 vti which I am having dificulty installing my flamer to. Everything is done,ie,spark plug in exhaust,switches etc. but am having problems locating which wire i have to snip to cut the spark for engine. I found several wires,which cutout the engine,but the idea of the switch is when it is pressed down,it temporarily cuts the spark allowing unburnt fuel to go through the exhaust,and when released,goes back to normal. but when the switch is pressed,it cuts the spark,but when released,the car seems to be going into safety mode and shuts down the engine. PLEASE HELP!
regards
KASH
Old May 26, 2004 | 04:48 AM
darkcvc's Avatar
Blue Sedan Crew
Default Re: Flamer Kit installation problem (Kream)
take all of it off and sell it to a 1950 Chooped top Mercury Coupe
dont put that thing on your car please dont......
Old May 26, 2004 | 04:51 AM
97ShLude's Avatar
Jesus, darkcvc your pic is freakin awesome. Nice a$$.
Old May 26, 2004 | 04:52 AM
Kream's Avatar
Help? Anyone??
cheers
Old May 26, 2004 | 05:45 AM
darkcvc's Avatar
Blue Sedan Crew
Default Re: (97ShLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ShLude &raquo;</TD></TR><TR><TD CLASS="quote">Jesus, darkcvc your pic is freakin awesome. Nice a$$.</TD></TR></TABLE>
thanks
Old May 26, 2004 | 06:07 AM
hatchdrvr's Avatar
Uh oh...here we go. You had better put on your fire proof suite.
Old May 26, 2004 | 06:15 AM
CivicEX96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kream &raquo;</TD></TR><TR><TD CLASS="quote">Flamer Kit installation problem</TD></TR></TABLE>
wow lol this is gonna be bad
Old May 26, 2004 | 06:22 AM
Luserkid's Avatar
Default Re: Flamer Kit installation problem (CivicEX96)
I would imagine if you lost your spark for even for a second then your motor would throw a code and shut off (like it is). Your motor isnt that stupid that if it sees no spark to keep running and blow itself up, thats why its doing what its doing.
I would take it to the local ricer shop and have them finish the project for you. I mean better safe then sorry you know? Well unless if you like being blown up, then knock yourself out.
Old May 26, 2004 | 06:55 AM
ScrapinSi's Avatar
Default Re: Flamer Kit installation problem (Luserkid)
also, flame thrower kits won't work if you have a catalytic convertor.
Old May 26, 2004 | 07:43 AM
JDMlyfestyle's Avatar
http://www.clubsi.com for all your F&F needs. everything to huge body kits 19" wheels neon lights they can help you with all your dumb *** ricer needs
Old May 26, 2004 | 07:45 AM
bbarbulo's Avatar
96+ cars have OBD2 which senses when the engine has misfired (which is what you're trying to do). It won't let raw fuel go into the exhaust cuz it'll kill your catalytic converter. Happened to my buddy's Protege when his coil pack went dead, and it killed his O2 and his catalytic converter. Don't do it, your car is not made for it. If you want, you *could* put a fuel injector in your exhaust right at the tail pipe. But why?? I can't understand.
BTW, there are these gas flame kits, you shoot gas into your exhaust and it gives off diff't color flames depending on what gas you charge the bottle with. Pure 2F2F stYlez
Old May 26, 2004 | 08:31 AM
94civicsally's Avatar
Default Re: (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle &raquo;</TD></TR><TR><TD CLASS="quote">[ help you with all your dumb *** ricer needs</TD></TR></TABLE>
You got it guy! LOL Unbelievable... people, more like flamers
Old May 26, 2004 | 08:42 AM
Louie_EM1
Guest
Posts: n/a
Default Re: (94civicsally)
**** that, just cut yourself dude.
<FONT SIZE="3">DIE!!!!!!</FONT>
Old May 26, 2004 | 08:47 AM
ABK's Avatar
ABK
Default Re: (Louie_EM1)
End you missarable life and jump of the cliff but first sell me your car for a $1.
Old May 26, 2004 | 08:49 AM
137's Avatar
137
You forgot to install the rainbow license plate bracket on your honda. It will not work w/o that and shaving tips from queer eye for the strait guy. good luck!
Old May 26, 2004 | 09:13 AM
Kream's Avatar
Default Re: (bbarbulo)
Iv'e already de-catted the exhaust,so thats not a problem.Is there any way to disable this OBD2 sensor?
it seems your one of the few who is actually trying to help here,cheers
Kash
Old May 26, 2004 | 09:27 AM
drewbie's Avatar
Default Re: (Kream)
just hard wire a switch to the coil and ignition or whatever makes the fuel go into the exaust.
maybe you should watch trucks more often (with stacey david)
Old May 26, 2004 | 09:35 AM
JustinL's Avatar
Default Re: (Mr. Teal)
run propane straight into your exhaust then put a spark plug and coil. hit the button and take a pic so i can see how it works
slow_cx
Dec 29, 2007 04:56 PM
EF8 JUNKIE9
25
Oct 12, 2006 08:05 AM
oxSLEEPERxo
Mar 18, 2005 11:23 AM
oxSLEEPERxo
Mar 18, 2005 10:14 AM
97EX
28
Sep 30, 2003 04:31 AM
