Flamer Kit installation problem
Hi there,I have a 1997 honda civic 1.8 vti which I am having dificulty installing my flamer to. Everything is done,ie,spark plug in exhaust,switches etc. but am having problems locating which wire i have to snip to cut the spark for engine. I found several wires,which cutout the engine,but the idea of the switch is when it is pressed down,it temporarily cuts the spark allowing unburnt fuel to go through the exhaust,and when released,goes back to normal. but when the switch is pressed,it cuts the spark,but when released,the car seems to be going into safety mode and shuts down the engine. PLEASE HELP!
regards
KASH
regards
KASH
Blue Sedan Crew
Re: Flamer Kit installation problem (Kream)
take all of it off and sell it to a 1950 Chooped top Mercury Coupe
dont put that thing on your car please dont......
Blue Sedan Crew
Re: (97ShLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ShLude »</TD></TR><TR><TD CLASS="quote">Jesus, darkcvc your pic is freakin awesome. Nice a$$.</TD></TR></TABLE>
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kream »</TD></TR><TR><TD CLASS="quote">Flamer Kit installation problem</TD></TR></TABLE>
wow lol this is gonna be bad
Re: Flamer Kit installation problem (CivicEX96)
I would imagine if you lost your spark for even for a second then your motor would throw a code and shut off (like it is). Your motor isnt that stupid that if it sees no spark to keep running and blow itself up, thats why its doing what its doing.
I would take it to the local ricer shop and have them finish the project for you. I mean better safe then sorry you know? Well unless if you like being blown up, then knock yourself out.
http://www.clubsi.com for all your F&F needs. everything to huge body kits 19" wheels neon lights they can help you with all your dumb *** ricer needs
96+ cars have OBD2 which senses when the engine has misfired (which is what you're trying to do). It won't let raw fuel go into the exhaust cuz it'll kill your catalytic converter. Happened to my buddy's Protege when his coil pack went dead, and it killed his O2 and his catalytic converter. Don't do it, your car is not made for it. If you want, you *could* put a fuel injector in your exhaust right at the tail pipe. But why?? I can't understand.
BTW, there are these gas flame kits, you shoot gas into your exhaust and it gives off diff't color flames depending on what gas you charge the bottle with. Pure 2F2F stYlez
Re: (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle »</TD></TR><TR><TD CLASS="quote">[ help you with all your dumb *** ricer needs</TD></TR></TABLE>
You got it guy! LOL Unbelievable... people, more like flamers
You forgot to install the rainbow license plate bracket on your honda. It will not work w/o that and shaving tips from queer eye for the strait guy. good luck!
Re: (bbarbulo)
Iv'e already de-catted the exhaust,so thats not a problem.Is there any way to disable this OBD2 sensor?
it seems your one of the few who is actually trying to help here,cheers
Kash
Kash
Re: (Kream)
just hard wire a switch to the coil and ignition or whatever makes the fuel go into the exaust.
maybe you should watch trucks more often (with stacey david)
oxSLEEPERxo
03-18-2005 11:23 AM
oxSLEEPERxo
03-18-2005 10:14 AM
