what makes a nitrous bottle valve leak?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by londa hover »</TD></TR><TR><TD CLASS="quote">bunp</TD></TR></TABLE>
i think i have a leak cause when i fill my bottle it only last for 5 runs on a 75shot. and when i turn my bottle on and off the pressure goes up to 900 and if i dont purge it, the pressure will be all gone in about a 20 minutes.
i was also wondering whats the highest pressure you guys have had your bottle press. gauge say? mine reads barely under 900 when its full, and with the bottle heater barely over 900 except last time i put it in a bucket of ice for an hour, then filled it right after and i got it to say 1100. shouldnt my bottle heater make the pressure go up to 1200 though? what else can i use to make my bottle pressure be at 1200?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IROSOLO »</TD></TR><TR><TD CLASS="quote">IF YOU LEAVE THE NOS IN THE LINE IT WILL EVENTUALLY SEEP THROUGH THE LINE AND YOUR NOS WILL RUN OUT. </TD></TR></TABLE>
But not in 20 minutes.
Check all your fittings and make sure they are tight. Listen/smell for leaks also. You will be able to smell the sulfer.
Modified by Cyphear at 5:53 PM 6/23/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">too much pressure.
You will hear it when you have a leak . and sometimes you can see it frosting over where the leak is. depends on the size of it. </TD></TR></TABLE>to much pressure? like more than 1200? what if i fill my bottle but dont use it for a couple weeks, could that start a leak
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by megotvtec »</TD></TR><TR><TD CLASS="quote">to much pressure? like more than 1200? what if i fill my bottle but dont use it for a couple weeks, could that start a leak</TD></TR></TABLE>
if u dont use the bottle, it should not leak. if the valve is bad, it will leak, but a good bottle will hold it for a long time...not sure how long, but my cousin had a bottle full for over 2 years in his garage, and used it recently.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J337_UNIT »</TD></TR><TR><TD CLASS="quote">
if u dont use the bottle, it should not leak. if the valve is bad, it will leak, but a good bottle will hold it for a long time...not sure how long, but my cousin had a bottle full for over 2 years in his garage, and used it recently.</TD></TR></TABLE>thanx!
