dsm 450cc install
Old May 25, 2004 | 01:17 PM
GReddy SI's Avatar
Default dsm 450cc install
ok i installed the dsm 450cc injectors in , now i am doing the wiring
from the Resistor box there 4 black wires and they are supposed to
be wired to each yellow/black wires on the injector. correct ?
now my question is where does the Red wire connect to ?
Old May 25, 2004 | 01:19 PM
GReddy SI's Avatar
Default Re: dsm 450cc install (GReddy SI)
here are some pics of the wiring
where does this connect to ? red wire
Old May 25, 2004 | 01:36 PM
GReddy SI's Avatar
anyone know
krazyDOHC's Avatar
the red wire on the resistor box goes to the other end of the yellow/black wire going to the ecu.....some people say to use only one....but i hooked up all 4 to the one red wire
Old May 25, 2004 | 01:52 PM
djfob's Avatar
awesome write up
https://honda-tech.com/zerothread?id=517274
Old May 25, 2004 | 02:03 PM
Luserkid's Avatar
Default Re: (djfob)
Do you need a resistor box in order to run DSM 450s? because im about to install mine once i get my fuel pump and i would like to know. If so where do i get them from? (what car)
Old May 25, 2004 | 02:08 PM
jolt-tsp's Avatar
Default Re: (Luserkid)
You don't need a resistor box, but you do need to put 10 watt 10 ohm resistors inline with the injectors.
I stole that pic and info from
http://www.homemadeturbo.com/t....html
Old May 25, 2004 | 06:36 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (djfob)
this is a goodone too
https://honda-tech.com/zerothread?id=216710
Old May 25, 2004 | 07:10 PM
GReddy SI's Avatar
Default Re: (boostedcivicsir)
ok guys , just talked to a buddy of mines and he told me this...
yellow/black wires go to the black wires on the res. box
the red wire from the box , i can run 4 wires from the red one
to each color on the injector ... like run a red to the blue, red to yellow , red to brown , red to red on the injectors
is this correct?
Old May 25, 2004 | 07:21 PM
GReddy SI's Avatar
Default Re: (GReddy SI)
anyone?
Old May 25, 2004 | 07:26 PM
djfob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GReddy SI &raquo;</TD></TR><TR><TD CLASS="quote">ok guys , just talked to a buddy of mines and he told me this...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazySOHC &raquo;</TD></TR><TR><TD CLASS="quote">the red wire on the resistor box goes to the other end of the yellow/black wire going to the ecu.....some people say to use only one....but i hooked up all 4 to the one red wire</TD></TR></TABLE>
This sounds right
Old May 25, 2004 | 07:33 PM
GReddy SI's Avatar
Default Re: (djfob)
i see that i have to wire the rest to the 4 other wires
but on mines i am missing one
Old May 25, 2004 | 07:35 PM
GReddy SI's Avatar
i dont have that thing to test to see which ones go to the injectors , and the others to the red wire
thats why i am wondering if i can just run a red wire to each color on the injector to make it work
Old May 25, 2004 | 07:57 PM
dcsports's Avatar
bump i whould like to know also
Old May 25, 2004 | 08:20 PM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">this is a goodone too
https://honda-tech.com/zerothread?id=216710</TD></TR></TABLE>
from this thread
Old May 25, 2004 | 09:59 PM
GReddy SI's Avatar
i know that , but i went the res box way ....
Old May 25, 2004 | 10:51 PM
GReddy SI's Avatar
bump
Old May 25, 2004 | 11:18 PM
91glassycrx's Avatar
okay guyz how hard is it to get the injectors into the fuel rail I heard u had to drill something out.
Old May 25, 2004 | 11:20 PM
GReddy SI's Avatar
Default Re: dsm 450cc install (91glassycrx)
u might have to sand the inside of the O ring a bit for your injectors to fit right in
Old May 25, 2004 | 11:30 PM
GReddy SI's Avatar
oh crap it
is this the right number for the
10 ohm 10W 5% Wirewound Resistor pk/2
$1.79 Brand: RadioShack
Catalog #: 271-132 Model: 271-132
this the right ones i need
http://www.radioshack.com/prod...1-132
Old May 26, 2004 | 12:29 AM
MPower332TI's Avatar
Man you guys are making this way to hard. The red wire needs to be wired to a 12volt switched source on the engine harness. Tap it into something. Then the 4 black wires go to the yellow and black of each injector. One per wire. Bam your done. Power is sent thru the red wire thru the box which ads resistance to the black wires and into the injectors. Hope that helps.
Old May 26, 2004 | 06:08 AM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91glassycrx &raquo;</TD></TR><TR><TD CLASS="quote">okay guyz how hard is it to get the injectors into the fuel rail I heard u had to drill something out.</TD></TR></TABLE>
yea you have to bore out the inside of the O-rings. im doing it now and its more of a pain in the *** than i thought, but still not too bad. im finding that i need to take out more material then i thought i would...
Old May 26, 2004 | 06:45 AM
Happyman's Avatar
Default Re: dsm 450cc install (blackeg)
Let me see if I can explain it so you guys understand it. There should be 5 wires coming out of the resistor box. All of mine were the same color I believe. First, go to the injector and find the yellow/black wires. Cut them, but make sure that the wires will reach the resistor box. You need to solder 1 of each of the yellow/black wires that are coming from the injector to 1 of each of the 4 wires off the resistor box that are the same color. Then you need to wire the other side of the yellow/black wires that are coming from the wire harness now to the remaining wire. All 4 coming from the wiring harness get soldered to this one wire. It is pretty easy once you understand it. Took me a little bit to understand but I got it.
Old May 26, 2004 | 10:50 AM
GReddy SI's Avatar
Default Re: dsm 450cc install (Happyman)
well i connected and it started up
but it runs really bad like if i am running on 3 cycl
what can be wrong ?
how can i check if the injectors work
Old May 26, 2004 | 11:36 AM
Cruiser G's Avatar
Default Re: dsm 450cc install (MPower332TI)
the resistor box just goes inline with the yellow/black ground wires. 4 go in through the 4 same color wires on the box, 4 go out through the one big *** wire on the box. thats all
