crappy idle, wont idle if it does.. checked everything. searched for days
Old May 25, 2004 | 12:51 PM
909rex's Avatar
Default crappy idle, wont idle if it does.. checked everything. searched for days
91 Honda CRX SI B18c1
Skunk2 IM
Skunk2 Stage 2 Cams
Skunk2 Spring, Valves, and Retainers
AEM Fuel rail with regulator
everyting else is stock...
car is throwing no codes what so ever.. only when i drove it 50 Feet it threw Code 5 MAP sensor.. but fixed it and no more codes.... checked all vacum hose's.. the vacum gauge says when it does idle goes from 15 to 10 and back a fourth... also the car isnt burning all the fuel and running really rich and i cant adjust the idle witht he adjuster on top of the TB... tried 3 IAC's not a change at all.. 2 different MAP sensors still no change... 3 different TB's nothin... i dunno what to do anymore... i sealed everything with seal just to make sure of the damn thing.. but no luck... any info is greatful
also i just read in another post that theres another idle adjustment screw on/or under the butteerfly..
Old May 25, 2004 | 05:16 PM
909rex's Avatar
Default Re: crappy idle, wont idle if it does.. checked everything. searched for days (909rex)
just did a comp. check and all 4 are perfect... and did spark check getting great spark... any ideas?
Old May 26, 2004 | 03:15 PM
909rex's Avatar
Default Re: crappy idle, wont idle if it does.. checked everything. searched for days (DVbitch)
its idling now but wont go past 3500 or 4000 i think its the timing
dotasefu
Oct 26, 2012 09:19 PM
EJ8chu
Engine Management and Tuning
32
Jun 1, 2008 10:19 AM
em1gangsta
Jan 26, 2008 03:40 PM
welfarepc
Sep 13, 2007 05:15 PM
ED9man
Jan 10, 2007 07:13 PM
