Whats the best way to keep IC pipes and intake temps down...
Old May 25, 2004 | 10:10 AM
wade's Avatar
Default Whats the best way to keep IC pipes and intake temps down...
i am running a 92 turbo integra. my underhood temps are very warm, whats the best way to keep my IC pipes cooler? once drivien, u cant keep your hand on the IC pipes for more then 3 seconds. i didnt know if insulation wrap would just keep in the heat in the pipes?
thanks
wade
Old May 25, 2004 | 10:23 AM
B18 CYA's Avatar
prop up ur hood on the end by the windshield using washers. It make look kinda ugly but hey, whatever cools ur engine....
Old May 25, 2004 | 10:28 AM
wade's Avatar
Default Re: (c2nap)
i herd that way back, does that reallly work?
Old May 25, 2004 | 10:43 AM
Egg-weezy's Avatar
Default Re: (wade)
I see 3 donkeys ^^^^(altavars) hahaha
Put anything on them that will create some kind of insulation. Such as paint, heat wrap, heat shields, ice, whip cream, or frozen meat!!
Two would be to create some kind of outlet for the 'trapped' heated air such as a vented hood, no fenders, or holes in your firewall.
Old May 25, 2004 | 10:47 AM
fjt's Avatar
fjt
Default Re: (MidoriHB)
Paint your block with heat paint..thats one of its function to lower temps on the engine bay. Try doing some kind of insulation on the Turbo manifold,that is the greatest heat source under your engine bay. Do heat wrap on the Manifold.
94eg5squadMD
Jan 28, 2016 12:31 AM
Rat Rod
Nov 12, 2010 03:57 PM
kevdix
Aug 4, 2009 05:00 PM
PM-Performance
May 4, 2004 11:48 AM
NONKonformyst
May 16, 2002 07:05 AM
