P07 Vx ECU to Run B16B/B18C (spec-R)
Old May 25, 2004 | 09:14 AM
edo3276's Avatar
Default P07 Vx ECU to Run B16B/B18C (spec-R)
Just wondering....KATMAN, on his old jdmhondaparts ecu tuning section (http://www.jdmhondaparts.com/ecu.htm) that the Vx (chippable version) ECU could be reprogrammed/chipped to run DOHC VTEC...but seconary Butterflies open....He also said that its almost identical to p28?.....
Anyone here using this Vx ECU to run DOHC??....please shed some knowledge into this...
ECU chipping and programming How to would also be great... Thanks!
Old May 25, 2004 | 09:21 AM
B_CRUZ!'s Avatar
Default Re: P07 Vx ECU to Run B16B/B18C (edo3276)
it will not open secondaries. I think you are confused. it is chippable though just like a p28/p30/p72
Old May 25, 2004 | 09:24 AM
edo3276's Avatar
Default Re: P07 Vx ECU to Run B16B/B18C (b cruz)
this is what i read..... from http://www.jdmhondaparts.com/ecu.htm....
"A chipped P28 will not control these secondary butterflies - they will stay open all the time which is not good.
Why? Because running the stock GSR intake manifold with a chipped P28 ECU, which doesn't control the secondaries and leaves them wide open will make you lose about 10ft. lbs. of torque! This has been dyno proven (thanks to Joe.R/honda-hybrid site). So, it's not a good idea leaving the secondaries open. I hear how a lot of people think that leaving these butterflies open will make a GSR/B18C engine more Type-R like....that is a load of hog poop." ....
Old May 25, 2004 | 09:30 AM
B_CRUZ!'s Avatar
a lot of us B18C guys dump the stock manifold for the skunk2 piece.
your first post doesn't make sense.
absorb this knowledge that I am about to spew to you...
It doesn't matter what ECU you chip... it can be a p28 or p72 or even a p07, it will run off of the chip. ALL of the settings will run of the chip. you can put a Mugen clone chip on a p72 and it will run identical if you put that same chip in a p28.
Old May 25, 2004 | 09:34 AM
melfice's Avatar
something just crossed my mind.. i have an old P07 i'm not using because i swaped the engine some time ago.. where could i buy i chip to make it a p28.. or could i buy a cheap ebay cheap? the ones that they can set the rev limiter, vtec crossover and auto to manual.. and would it work like a regular p28? thx
Old May 25, 2004 | 09:36 AM
B_CRUZ!'s Avatar
Default Re: P07 Vx ECU to Run B16B/B18C (melfice)
its not something that I would DIY if you aren't experienced at soldering... you can send it out to Katman or EG6AJK for a fee. They are very experienced chippers I can vouch for.
Old May 25, 2004 | 09:43 AM
melfice's Avatar
i have a frind that has chipped some ecus before..
would this chip for example work? i'm not expecting HP gain i just wanna be able to use it as a P28 and cheap.. thx
http://cgi.ebay.com/ebaymotors...33597
Old May 25, 2004 | 11:29 AM
melfice's Avatar
bump.. anyone?
dturbo
Oct 17, 2005 08:00 PM
eg6hatch
Aug 7, 2003 04:29 PM
UltRaH22
Apr 8, 2003 10:12 PM
ahcjar103
Mar 13, 2002 04:27 AM
