please help, timing issue.
Old May 25, 2004 | 08:42 AM
1.7na's Avatar
Default please help, timing issue.
I recently swapped cams out and notice that I can't seem to get my timing back to 16 without fully advancing my distributor. My timing is at about 8 right now. I have already triple check and made sure that my gears are lined up correctly (UP,UP and >&lt, crank was lined up with the TDC mark (white), I also stuck a wooden stick in clyinder 1 and made sure it was at TDC. I used two pin punches to hold the cams in place. Everything also lined up even after I cranked the crankshaft 3-5 times (counterclockwise). My timing is at about 8 right now. I do have a 2 layer headgasket but already advance the intake cam gear 2 degress (head is not milled). Does anybody else know what else I should check for or could be causing this problem. Can the oil pump TDC mark be off even if I didn't take off the crank pulley? I had this problem for awhile now but I need to get this fixed soon because my smog is due. I'm stumped on this one. I apperciate any advise!
thanks
1.7na
Old May 25, 2004 | 08:51 AM
mmuller's Avatar
Mad Scientist
Default Re: please help, timing issue. (1.7na)
for every .012 (about) you remove from hg or mill cam timing is retarded by 1degree. try retarding both cams about 1 degree. and see what happens
Old May 25, 2004 | 09:09 AM
1.7na's Avatar
Default Re: please help, timing issue. (mmuller)
mmuller,
Thanks! Should it be advance or retard? I didn't adjust the exhaust cam but I will give everything a try tonight.
thanks again!
1.7na
Old May 25, 2004 | 12:41 PM
1.7na's Avatar
anybody know what else I might want to check?
thanks
1.7na
d16trex
Jul 17, 2008 11:04 AM
krazeenoy
Jun 20, 2008 06:10 AM
G2Crash
Feb 5, 2005 06:44 PM
spooned out
Aug 10, 2003 08:19 PM
VisualEcstasy
Apr 15, 2003 09:00 AM
