Help with TPS voltage issue...
Old May 25, 2004 | 08:42 AM
wade's Avatar
Default Help with TPS voltage issue...
At idle, my TPS reads .5V on the nose, and as i open up the throttle everything reads fine except for when i reach about 3/4 throttle then the voltage goes to zero from 3/4 to WOT. Whats the deal? I replaced the TPS with a newer one and got the EXACT same problem.
THanks
wade
Old May 25, 2004 | 09:37 AM
speedDOHCtors's Avatar
Default Re: Help with TPS voltage issue... (wade)
TPS Sensors are very touchy sometimes. If it continues not to work. You might want to check the TPS wire on your ecu. Sometimes it does come loose. It happens to a lot of customers. Also, make sure the setting of the TPS is correct. But most likely it is a wiring problem somewhere.
Old May 25, 2004 | 09:43 AM
wade's Avatar
thanks, i heard jus now with a hondata it should be at .45V, so i will get on that later when i get home from work
keep them coming
ALSO< where do all 3 of the TPS wires go to from the plug? do all 3 go to the ECU?
Old May 31, 2004 | 12:32 AM
frenchy's Avatar
Default Re: (wade)
all 3 wires run to the ecu - same color on both ends so its easy to find
cranker
Jul 15, 2010 03:22 PM
1Bluegsr
Jan 16, 2010 12:12 PM
tmurda253
Nov 14, 2008 12:19 AM
VAturbob20
Dec 28, 2005 05:55 PM
Darkteg
Aug 17, 2003 12:47 PM
