1998 Civic - Keyless remote has stopped working
Old May 25, 2004 | 08:37 AM
shnichol's Avatar
Default 1998 Civic - Keyless remote has stopped working
My keyless remote stopped working. I have changed the battery (and programmed per the owners manual), checked the fuse...still it won't work. The light on the remote does light up when the button is pushed. Any suggestions on what could be wrong?
Old May 25, 2004 | 08:42 AM
pdiggitydogg's Avatar
did you change your radio to an aftermarket?
Old May 25, 2004 | 08:46 AM
shnichol's Avatar
Default Re: (pdiggitydogg)
No, nothing has changed on the car.
Old May 25, 2004 | 09:03 AM
pwrofdrm's Avatar
Default Re: (shnichol)
Is it the Honda OEM control? Don't know if this helps, but if you want I have my two old ones laying around...they are yours if you want to try.
Old May 25, 2004 | 09:29 AM
EL Vap133's Avatar
Default Re: 1998 Civic - Keyless remote has stopped working (shnichol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shnichol &raquo;</TD></TR><TR><TD CLASS="quote">My keyless remote stopped working. I have changed the battery (and programmed per the owners manual), checked the fuse...still it won't work. The light on the remote does light up when the button is pushed. Any suggestions on what could be wrong?</TD></TR></TABLE>
Maybe it's time for a new transmitter?
Old May 25, 2004 | 10:01 AM
shnichol's Avatar
Default Re: (lax1185)
Yes it is the OEM control. It just happened a few days ago so I'm not ready to give up yet. Thanks for the offer.
Old May 25, 2004 | 10:07 AM
shnichol's Avatar
Default Re: 1998 Civic - Keyless remote has stopped working (EL Vap133)
Thanks, I'll check in to that possibility.
Old May 25, 2004 | 10:12 AM
EL Vap133's Avatar
How long have you had the car/keyless remote entry for?
Old May 25, 2004 | 10:41 AM
shnichol's Avatar
I bought it new in March 1998.
Old May 25, 2004 | 12:02 PM
axhandler's Avatar
Are you sure your following the directions correctly?
https://honda-tech.com/zerothread?id=807030
Old May 26, 2004 | 08:47 AM
shnichol's Avatar
Default Re: 1998 Civic - Keyless remote has stopped working (axhandler)
THANK YOU, THANK YOU, THANK YOU! Your directions worked perfectly and fixed the problem. Sorry it took me a while to respond, I tried yesterday but I guess I had exceeded my 5 posts as a new member. I appreciate your help...you made my day.
Old May 26, 2004 | 08:55 AM
axhandler's Avatar
Hey...no problem...
HRD
31
Apr 15, 2017 07:31 PM
aowtkm
Audio / Security / Video
Nov 28, 2011 03:44 AM
ZexyAccord
Nov 10, 2007 10:32 AM
Hyjnx
Sep 11, 2005 09:08 AM
ImXposed
Aug 31, 2005 06:28 AM
