Honda S2000 Honda S2000
problem with vtec engagement...
Old May 25, 2004 | 12:23 AM
SP00N's Avatar
Default problem with vtec engagement...
when i down shift to first and hit vtec my engine shuts off... any ideas?
Old May 25, 2004 | 06:10 AM
Mr. Bagel's Avatar
Default Re: problem with vtec engagement... (SP00N)
uhhhhhh. three bars right?
Old May 25, 2004 | 09:23 AM
Mase's Avatar
yeah make sure your engine is fully warm, also does it shut off completely or just hit a brick wall when vtec tries to engage?
Old May 25, 2004 | 05:54 PM
SP00N's Avatar
Default Re: problem with vtec engagement... (Mase)
yeah, the engine is warmed up and it completely shuts off. kinda scares me. it only happened after i installed my dc stainless steal header.
Old May 27, 2004 | 05:33 PM
SP00N's Avatar
any other input wold be helpful thans
Old May 27, 2004 | 05:36 PM
evil vapor's Avatar
Default Re: (SP00N)
has your engine wiring harness been messed with? install of a vafc?
state mods on the car, when the problem started, etc etc etc
Old May 27, 2004 | 07:59 PM
Slow_Em1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SP00N &raquo;</TD></TR><TR><TD CLASS="quote">when i down shift to first and hit vtec my engine shuts off... any ideas?</TD></TR></TABLE>then dont downshift to first
Old May 27, 2004 | 10:22 PM
SP00N's Avatar
problem started when header was installed, only mods are intake, header and throttle body.
everything was fine until the header install.
Old May 27, 2004 | 11:36 PM
evil vapor's Avatar
Default Re: (SP00N)
just stating the obvious since there isn't a lot of info to work with, try installing the stock header and see what happens If the install went properly, I can't see a reason why your having issues. A wire could've been damaged in the install, a connector unplugged and not plugged back in. It could be many things.
Old May 28, 2004 | 04:09 AM
Atheist's Avatar
I'd bet that if anything, you diconnected a cable.
Old May 28, 2004 | 06:26 AM
Mr. Bagel's Avatar
Default Re:
doubtful that it's the header. perhaps theTB if anything at all due to the TPS sensor, IIRC on the S. Not sure how adjustable it is, but it must be tuned correctly.
Can you describe the scenario a bit more? Going at X speed, downshift to 1st... then what?
Do you blip the throttle at all?
Old May 28, 2004 | 09:33 AM
Mr Boston's Avatar
Default Re: Re: (Mr. Bagel)
Do you have a CEL? You might be in limp mode
Old May 28, 2004 | 11:18 AM
$pecial K's Avatar
[QUOTE=SP00N]when i down shift to first and hit vtec my engine shuts off... any ideas?[/QUOTE=SPOON]
U down shift to first??? How fast were u going???
Modified by $pecial K at 12:17 PM 6/4/2004
Old May 28, 2004 | 07:35 PM
SP00N's Avatar
sorry, i'll try to be a little more detailed.
when the intake and TB was installed NP's.
after the header install, installed by Honda,
the engine will gradually shut itself off when i hit vtec.
it isn't always downshifting to first at any speed that does it. sometimes i just launch it in first, (full throttle after the initial wheel spin, and when vtec comes along, the rpms start moving backwards. hope thats detailed enough
Old May 31, 2004 | 12:42 PM
SP00N's Avatar
updated
Old Jun 1, 2004 | 01:59 PM
[pH]Amuse's Avatar
perhaps the header is leaking? did you put the header gasket on with it?
Old Jun 1, 2004 | 03:37 PM
evil vapor's Avatar
Default Re: (SP00N)
so your dealer installed the header? if so, have you asked them why you're having problems?
Old Jun 1, 2004 | 06:48 PM
[pH]Amuse's Avatar
Default Re: (vapor)
well if it helps, i pmed him the same question, he said it's not the header install and if he wants them to look at it they'll go head and charge him up the ***. in my own words anyway
01em2slvr
Honda Civic (2001 - 2005)
Nov 11, 2009 12:43 PM
bazooka
Sep 5, 2006 04:13 AM
dAng! Kris
Sep 17, 2003 07:13 PM
ophdehEEzY
Apr 27, 2003 08:01 PM
Renegade
Mar 19, 2002 08:07 AM
