Nervous about oil return line..pic inside
Old May 24, 2004 | 05:38 PM
Rod.'s Avatar
Default Nervous about oil return line..pic inside
Dont say I need to get a new oil return line. Trying to make this work , if I cant then I will by a different one.
Does that kink in the middle make a difference? Does it look like it will work???? That is my most import question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredroSp &raquo;</TD></TR><TR><TD CLASS="quote">is it me or do you think the bung on the oil pan is a drop low?</TD></TR></TABLE>
[QUOTE=ladysman]Unless the pic is deceiving.
[\QUOTE]
Modified by redturbocivic at 4:03 AM 5/25/2004
Modified by redturbocivic at 4:07 AM 5/25/2004
Modified by redturbocivic at 4:10 AM 5/25/2004
Modified by redturbocivic at 4:11 AM 5/25/2004
Modified by redturbocivic at 4:12 AM 5/25/2004
Old May 24, 2004 | 05:46 PM
Ben Huynh's Avatar
Default Re: Nervous about oil return line..pic inside (redturbocivic)
It'll work fine.
Old May 24, 2004 | 05:49 PM
VacantBanana's Avatar
looks good to me, im using a crappy rubber hose and its working fine for months, gotta invest in steel braided before i leak
Old May 24, 2004 | 06:07 PM
5STAR3's Avatar
Default Re: Nervous about oil return line..pic inside (VacantBanana)
looks fine
Old May 24, 2004 | 06:09 PM
TRE_'s Avatar
looks good to me.
philipwight's Avatar
Default Re: Nervous about oil return line..pic inside (envision2teg)
clock the turbo cartrige a little more and you may be able to get the slack out
Old May 24, 2004 | 06:18 PM
JAY's Avatar
JAY
Default Re: Nervous about oil return line..pic inside (philipwight)
looks good to me
Old May 24, 2004 | 06:28 PM
Muckman's Avatar
Moderator in Chief
Why not just cut 1/2" out of the line and make the gradient smooth?
Old May 24, 2004 | 06:31 PM
DaveF's Avatar
Default Re: Nervous about oil return line..pic inside (Muckman)
why is the return tapped soooo low in the pan ?
Old May 24, 2004 | 06:32 PM
FredoSP's Avatar
Old May 24, 2004 | 06:40 PM
ladysman's Avatar
Default Re: Nervous about oil return line..pic inside (FredoSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">is it me or do you think the bung on the oil pan is a drop low?</TD></TR></TABLE>
I agree with Fredo, it looks low to me as well. It needs to be in the pan as high as possible. Unless the pic is deceiving.
Old May 24, 2004 | 07:15 PM
Rod.'s Avatar
Default Re: Nervous about oil return line..pic inside (ladysman)
edit another pic added
Old May 24, 2004 | 07:30 PM
B18Flip's Avatar
try bolting up the downpipe during the oil return install just to make sure it doesnt touch or get in the way....i didn't my first time and i ended up having to order more braided hose
Old May 24, 2004 | 07:58 PM
Rod.'s Avatar
Default Re: Nervous about oil return line..pic inside (B18Flip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Flip &raquo;</TD></TR><TR><TD CLASS="quote">try bolting up the downpipe during the oil return install just to make sure it doesnt touch or get in the way....i didn't my first time and i ended up having to order more braided hose </TD></TR></TABLE>
I wish I could. The muffler shop i took it to welded my 2.5 dp to my 3" exhaust . I thought they would put a flange to bolt them together. After they finished they told me I need to get a flex pipe then they will take care of it. I couldn't cause I didnt have a job back then.
Can I do this???? Cut the dp after the o2 bong and bolt it up. Break in my engine wtih that. I got a base map already put in my ecu for hondata. Will that mess anything up if I have my o2 plugged in and open dp???? This will on be till i get to the muffler shop
Thanks
turbotypeR@SPEC's Avatar
25 Year Member
it will smoke like that.the fitting is way to low in the tank.it is below the oil level.the hose should be 5/8 id as well.that doesn't look big enough.i would put it in the block.like this:https://honda-tech.com/zerothread?id=872528
Old May 25, 2004 | 06:14 AM
Rod.'s Avatar
Default Re: Nervous about oil return line..pic inside (turbotypeR)
bump for more opinions
Old May 25, 2004 | 08:35 AM
turbo*s2k's Avatar
Looks alright to me!
Old May 25, 2004 | 08:41 AM
B18C1CYA's Avatar
Default Re: Nervous about oil return line..pic inside (TurboChrgd_Civic)
i think it will be fine your drain on the turbo is higher than the oil level in the pan so it should drain without a problem i would think
Old May 25, 2004 | 08:47 AM
Pengo's Avatar
Default Re: Nervous about oil return line..pic inside (B18C1CYA)
the line looks ok. the fitting in the pan looks like it may be a little too low. can't tell if it'll be low enough to back up the line though. as for the bend in the braided line, if it really bothers you that much or gets in the way, just shorten the line and reinstall. better to be longer than shorter. then at least you can make adjustments now.
Old May 25, 2004 | 08:53 AM
sway892's Avatar
Default Re: Nervous about oil return line..pic inside (Pengo)
I don't know much about a lot, but that looks like is in the middle or damn
near.
P.S. hurry up and take the VIN off before the cops find it.
Old May 25, 2004 | 09:05 AM
Rod.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">i think it will be fine your drain on the turbo is higher than the oil level in the pan so it should drain without a problem i would think </TD></TR></TABLE>
I thought that too
PrecisionH23a
Welding / Fabrication
23
Dec 12, 2006 06:00 AM
teddy_dc2
Aug 10, 2006 06:11 AM
SM00TH976
May 17, 2006 08:59 AM
Novtecdohc
Aug 31, 2005 04:29 PM
shadow103rd
Jun 26, 2004 09:08 PM
