spark plugs
hey everyone, im new to the racing commnunity. just got my car
i gotta 1996 honda civic. i was gonna get these spark plugs http://www.jacksonracing.com/S...34109 but first i was wondering if spark plugs add hosepower to the engine or not. and also can any kind of spark plug go into my engine? cause wen i bought some new spark plugs wen i first got car (i was giving car a tuneup) i bought a certain kind for my car. someone please help, thx
All these plugs are is the standard ngk plug but colder plug. I belive its total b/s about lowering combustion temp. Best plugs are NGK. I have tried every plug and the standard NGK V-power runs the best. Iridium are just the same but last longer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n_23_s »</TD></TR><TR><TD CLASS="quote">All these plugs are is the standard ngk plug but colder plug. I belive its total b/s about lowering combustion temp. Best plugs are NGK. I have tried every plug and the standard NGK V-power runs the best. Iridium are just the same but last longer. </TD></TR></TABLE>
i totally agree, i would just go with the NGK v-pwr's and save your money from buying the iridium's.
No Sales Forums
your not gonna gain any hp with special plugs, they will make your car run colder but thats about it. buy some oem plugs(ngk) you dont need to go to the dealer for them
Combustion temp isn't b/s. You want to run the right heat range plug for optimum performance and longevity. I also recomend factory plugs unless you are doing a different form of aspiration or nitrous. For those its best to use colder plugs so you don't get detonation. Whatever you do, just don't waste money on expensive plugs because they don't make a difference that you will be able to notice.
wat about these plugs, http://www.ngksparkplugs.com/p...ry=US will that keep my engine cold, are they good? and if i get the spark plugs and put them in, i dont have to replace anything else right, cause last time i replaced spark plugs i just put em in but i have cheap ones right now
dont bother with anything but factory replacement plugs until you start getting some serious mods done. otherwise you're wasting your hard earned money for literally nothing.
LOSERboy
13
Aug 13, 2004 10:56 AM
