HELP fast...engine ID info
Old May 24, 2004 | 12:46 PM
94civicpat's Avatar
Default HELP fast...engine ID info
bought a hatch off my friend and he said there is a newer engine in the car. its a 93 si hatch and the block still reads d16z6 is there any way to tell if it is the original engine or not? sorry if this is a stupid ?
Old May 24, 2004 | 01:04 PM
CaptivaBlue's Avatar
Default Re: HELP fast...engine ID info (94civicpat)
Engines has VINs too, I don't think they correspond but find the engine vin- can't quite recall where it is but it should be obvious, then take the car vin and the engine vin and take them to a Honda dealer perhaps? They might point you in the right direction, either way, the D16Z6 won't be any newer than 1995.
Old May 24, 2004 | 01:06 PM
shogun1's Avatar
Yes there is. Take the whole serial # to your local dealer (hopefully they will help you) or a Honda shop and ask to look at the Helms shop manual for the motor(s) in question. The listings are toward the front of the book. The #'s following the D16z6 will determine the year that motor was installed.
Old May 24, 2004 | 01:09 PM
shogun1's Avatar
Also, If you take your Vin # to the Parts department at any honda dealer, they can look up the vin and tell you exactly which motor with serial #, that was in the car. If they say no, then they're full of it.
Old May 24, 2004 | 01:16 PM
Kruzen510's Avatar
on my 92 si valvecover d16z6, it just said honda but on my buddies 94 si valvecover it said vtec on it. not sure which year it changed but if that helps
crazyhouse2011
Oct 10, 2013 11:14 AM
Niev0000
Honda Civic (2001 - 2005)
Nov 17, 2011 06:12 AM
cksnah252
Nov 8, 2009 05:51 PM
eggsi619
16
Jul 19, 2009 01:06 PM
94CivicSi
Apr 7, 2005 06:03 AM
