my stock gsr motor
Old May 24, 2004 | 10:12 AM
miki d's Avatar
Default my stock gsr motor
i need some advice about building up my stock gsr motor
my goal in the future is definitly forced induction
id like the engine to be able to handle a 100-150 shot of nitrous
im pretty sure on stock internals it can already handle up to 75hp
i dont know much about engine internals unfortunetly, so i need some advice on what i will need to replace/upgrade to achieve that spray range safely
thanks a lot guys
Old May 24, 2004 | 10:55 AM
VacantBanana's Avatar
Default Re: my stock gsr motor (miki d)
for nitrious people usally recommend forged pistons along with good rods bc many times they can go right through the block. arp head bolts, change all the bearings and gaskets. should be good to go. all depends on how much power u are looking to make. forge cranks cost a pretty penny
Old May 24, 2004 | 10:59 AM
Egg-weezy's Avatar
Pistons, rods, sleeves, head bolts, head gasket and maybe some stronger valve train too. This will ensure that you'll run 150 safely for a long time to come. Why not go boost with the GSR. You could do it very easily with the amount of money your willing to throw down.
Old May 24, 2004 | 11:16 AM
miki d's Avatar
because i need an every day driver
i only want the power when i actaully need it...
the rest of the time a gsr motor is just fine
Old May 24, 2004 | 11:28 AM
i got a 90 teg with 135k on it running 10 psi on stock internals, hasnt had one problen, gsr s can handle great amounts of power with a t3/t4 setup, as long as u dont beat it id go for boost, with bigger turbos it spools slower so as long as ure not nailing the gas on every road id go boost with stock internals and save ure money for internals
417greenmachine
Oct 12, 2015 09:53 PM
Maxthepersonz
Jun 27, 2013 06:47 AM
shortstopNE
Dec 25, 2008 01:24 AM
92CivicLS
Jun 14, 2004 04:50 AM
