b18c1 built motor for boost question
Old Dec 24, 2008 | 12:57 PM
shortstopNE's Avatar
Default b18c1 built motor for boost question
I have a stock gsr in my civic right now thats boosted on 9psi. Was planning on running it but i have seen a couple of locals with their "fast" cars and i would like to play with them if ya get where im going. This is my first work with internals of a motor so i just wanna make sure i understand it before i do it.
My question is....
Building the block, I would like to do je pistons, eagle rods. I would also need new pins and bearings correct? Is a head gasket necessary with arp head studs and a block guard? Just trying to keep it simple but have a reliable go getter. I am searching more about it everyday but i run into a lot of all motor threads but i assume its practically the same. Would appreciate any help, info, advise. Probably leaving head stock at first. I wanna do everything at once and do it right. No numbers goal or anything, just for my personal enjoyment.
EDIT: move if necessary, posted here because its for forced induction but could also be all motor. Thanks!
Old Dec 24, 2008 | 04:50 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: b18c1 built motor for boost question
with the pistons comes the pins. to do all that you will need a headgasket anyway. do arp's with it apart, no need for a block guard. have someone competent tune it. if you are goin that far, have the crank checked and if it is ok, new bearings wont hurt.
Old Dec 25, 2008 | 01:24 AM
kyleb18t's Avatar
jeff evans will be doing blocks soon,stage 1 is good for 500hp i believe.and it will be done right.
skunk2 tuner stage 1 cams in the head are a good thought too.
superjet
Jul 30, 2012 10:08 PM
dorinkushi
Oct 22, 2010 05:44 AM
spooledex
Dec 2, 2008 07:03 PM
CDN Yellow ITR
Nov 17, 2003 07:28 PM
H22Prelude
Jun 27, 2003 06:18 PM
