Is this serious blow by or normal - oil squirting out when removed oil cap.
Old May 24, 2004 | 10:11 AM
JerseySiPOS's Avatar
Default Is this serious blow by or normal - oil squirting out when removed oil cap.
2000 Si
b16 stock bottom end
toda spec b cams, toda valve train, belt etc. (for a year now)
i check my valve clearances regularly, there are good.
timing is 17 degrees.
i want to go to the dyno....again
during the winter i noticed some smoke coming out my valve cover breather. maybe because it was crazy cold. dont know.
had some fuel supply problems, with my fpr, filter and injectors. just upgraded my entire fuel system so i know i have no fuel delivery problems when i go to the dyno.
but seems like untuned i cant extract any power in midrange and up top and feels like a big flat spot.
did the ghetto test. turned car on, took oil cap off. oil just squirts outta the valve cover, no smoke though. dont think it was like that last year, because didnt check.
there is no smoke coming out when i pull the dipstick out. i need a leak down test, but wanted to see if anyone has oil squirting out like that when removing the oil cap. idle seems smooth. thanks
oh yeah....compression is 200 across.
Modified by JerseySiPOS at 7:21 PM 5/24/2004
Old May 24, 2004 | 10:31 AM
dsadas89das78934's Avatar
the spray coming out of the oil cap is just from the rockers and various other valvetrain components spinnging and rocking and just generally moving around inside the head as the motor runs.
the 'smoke' you saw when it was cold was probably just some sort of steam.
Old May 24, 2004 | 11:05 AM
obd2gsr's Avatar
Default Re: Is this serious blow by or normal - oil squirting out when removed oil cap. (JerseySiPOS)
that's normal.
Old May 24, 2004 | 12:08 PM
Default Re: Is this serious blow by or normal - oil squirting out when removed oil cap. (obd2gsr)
THANK YOU!!
i would think its normal regardless whether i have big cams or not. it doesnt do it on my friends b16 with stock cams though.
anyway, does anyone ever clean out the pcv valve canaster behind the block?? i changed my valve cover gasket when i put my cams in and was thinking if taking the cover off regularly doesnt hold a seal as well as the valve cover grommets. oil just pushes its way past these areas. thanks
sleepergo
13
Apr 25, 2017 01:49 PM
SpeedMachine
Apr 29, 2005 12:27 AM
cornhusker
Dec 14, 2004 10:46 PM
B18PoweredCivic
May 10, 2004 10:04 AM
Kevin
Apr 22, 2002 09:02 PM
